Cowl VIN stamp 70 Challenger #1653485
07/31/14 09:26 AM
07/31/14 09:26 AM
Md.
J Brough Offline OP
J Brough  Offline OP
Md.
Started restoration of a 70 Challenger. Will need to replace the firewall and cowl panel due to excessive rust. What do restorers do about the VIN stamp on the cowl? Restamp the new panel? If so how? Or should it just be left unstamped?
Thanks,
John
Re: Cowl VIN stamp 70 Challenger [Re: J Brough] #1653486
07/31/14 09:59 AM
07/31/14 09:59 AM
Alabama
BigMoneyLewis Offline
Alabama
I believe the standard procedure is to cut out your numbers from your original cowl and cut /weld onto the new cowl.
Greg
gregward@mchsi.com phone 256-852-0955
Re: Cowl VIN stamp 70 Challenger [Re: J Brough] #1653487
08/01/14 08:38 PM
08/01/14 08:38 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
How bad is the upper cowl VS the firewall? I had the same situation where I wanted to save the upper cowl when I had to replace the firewall. I used a doaner section to repair my original and installed in on the new AMD firewall.
If its too far gone I would use a new cowl and keep the original section with the numbers in my file.
