Poll: 446"-470" B/RB or stock 6.4 Hemi #1653107
07/30/14 04:44 PM
07/30/14 04:44 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Trying to see what the world of moparts thinks about the following. Friend is doing a major revamp of his 70 Charger 500 clone. It's got a low compression 440 in unknown condition that we need to go through before it can be a very reliable driver.
440 Pro's and con's:
I'd like to build a copy of AndyF's 470ci B motor for his car. 3.900 crank, Eddy heads, Small Solid cam, Performer RPM intake and an Eddy 800 Thunder Series. I'd like to see about 450rwhp with his HP manifolds. He wants to use the car to corner carve around the Texas hill country. Just a weekend driver that he could hop in and knock off a few hundred miles in.
Pros:
It's already a bit block car. Ease of install.
We can reuse his existing HP manifolds
Doesn't need a whole lot of power out of it.
Looks like it should be there.
No need for EFI.(but it would be nice)
Can use all current accessories and fan.
Cons:
No EFI.
Limited by the cylinder head (Eddy Performer RPM or E-street)
Hydraulic or Solid cam (are they still wiping lobes?)
Will take some work to get his AC to work.
The other option is a box stock 6.4 Hemi.
Just a factory crate motor with TTI headers and a Milodon pan.
Pros:
Instant fire up and run
470hp with great torque out of the box.
Comes with a limited warranty
Will get better mileage.
Will live better with the EFI controling the AC.
Could be funded partly by the sale of old parts. Complete 440 and 727...
Cons:
EFI and swap accessories are $$$
Won't look as "appropriate"
Will require fuel system upgrades.
What would you chose?
single choice
Votes accepted starting: 07/30/14 02:43 PM
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: AlexP] #1653108
07/30/14 05:39 PM
07/30/14 05:39 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Pros:
Cons:
No EFI.
Pros:
Cons:
I vote for a 470"!
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: Uhcoog1] #1653109
07/30/14 05:46 PM
07/30/14 05:46 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Corner carver. No poll required because weight is the enemy. 6.4L
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: AlexP] #1653110
07/30/14 07:00 PM
07/30/14 07:00 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
As much as I like a big engine I went with the 6.4 hemi. You can do a LOT more with less work in the engine. The architecture of the heads is far more capable than the old big wedge.
It's also a significantly lighter engine which is what you want on a car built for handling.
- Stu Harmon
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: feets] #1653111
07/30/14 07:08 PM
07/30/14 07:08 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
budget wise you'd be better off with the 440. forget stroking it, reuse the stock crank, get some better rods and pistons. edelbrock heads, use the MP528 cam and you'll have all the torque you want in the corners.
that will save enough money to go with efi and getting the ac fixed. especially if you want to keep the stock exhaust manifolds. you can do a lot with the engine as is. maybe even step up to a custom ground cam for better performance, but personally I like the MP528. its got a wide flat torque curve and acts like a stocker in a 440. I'm running a the MP557 in my engine now, a little lumpier, but very tolerable. doesn't have the vacuum the MP528 does.
also get as many aluminum parts onto the front of the engine as you can. water pump and housing, intake, heads it will get you close to the 6.4L hemi
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: Jerry] #1653112
07/30/14 07:19 PM
07/30/14 07:19 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
We will build the new motor on the side and swap accessories at the time of install. Nothing off the longblock will be reused. That's why I'd rather gain some stroke while were at it.
I'm leaning towards a 400 block.
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: AlexP] #1653113
07/30/14 07:35 PM
07/30/14 07:35 PM
dogdays Offline
dogdays  Offline
The new Hemi is the way to go, it's a lot lighter than even an aluminum head B/RB.
It's also smaller, and can be put back farther in the chassis because of its size.
The kind of money you are talking about is substantial either way.
R.
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: dogdays] #1653114
07/30/14 09:26 PM
07/30/14 09:26 PM
Central NC
gch Online content
gch  Online Content
Central NC
If you have the funds then the 6.4 is great and with some boost could be nasty.
I don't have funds so I would do a stroker and if you want torque and are going to do a crank anyway then might as well do a 493/505.Go with alum heads.intake/water pump and housing and switch to a late model sanden compressor for the a/c.
Next question is what gearing and trans??Lots more money for the 6.4 swap but the best of both worlds.
With a BB stroker you don't need deep gears or high stall converter so a lot less money spent on the drive train.
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: gch] #1653115
07/30/14 09:47 PM
07/30/14 09:47 PM
BDW Offline
BDW  Offline
If he' going to drive the car, it doesn't even seem like a fair comparison.
Why in the world would you not put a modern motor in it?
New Hemi is a no-brainer
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: AlexP] #1653116
07/30/14 11:35 PM
07/30/14 11:35 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
Hellcat motor!!!!!!
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: jrlegacy23] #1653117
07/31/14 12:39 AM
07/31/14 12:39 AM
IN
ahy Offline
ahy  Offline
IN
The BB stroker and Hemi will act different in the car. The BB will have "effortless" mid range torque and the Hemi will like/need RPM. Rear gearing would need adjusted accordingly and the Hemi would be happier with more gears (4 speed auto or 5 speed manual or better) vs the RB.
An RB built with aluminum heads and WP won't be that much heavier than the Hemi. With suspension mods and battery in trunk, balance and handling can be pretty good with the RB. It comes down to what you like.
If you do choose the RB, suggest you go for the 4.15 stroke option (493" or what ever). There is no real durability or cost penalty vs a 470 and more torque. It should work well with mildly worked Ed heads (minimum) and a moderate cam.
For reference, I run a 496" lowdeck in a '70 E with Ed heads/aluminum WP and battery in trunk. 3.23 rear, 25.x" tires and 5 speed. With beefed suspension, it handles the twisties quite well and I enjoy the mid range torque.
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: ahy] #1653118
07/31/14 02:03 AM
07/31/14 02:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I think you know what my choice would be. To me that Charger just looks right with the bigblock 440/stroker in it. The 6.4 is a great eng but it just dont look right in that Charger to me. My 493 is very streetable as I drive it all the time on the street and pushes my 63 into the 10's but I do use headers. Honestly though he has to do what he wants as it is his car. Ron
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: 383man] #1653119
07/31/14 02:21 AM
07/31/14 02:21 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
470 low deck with Indy SR heads.
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: Darryls-Demon] #1653120
07/31/14 03:21 AM
07/31/14 03:21 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Injected big block with aluminum heads and WP. Everything is a bolt in and 500 inchs of torque will move that heavy Charger.
Sheldon
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: AlexP] #1653121
07/31/14 06:25 AM
07/31/14 06:25 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Hard decision, I have done the stroker big block with EFI, overdrive trans, aftermarket accessory drive, and it is alot of work, and can get expensive if using the expensive stuff. There is no way I could have done it if I had to pay labor for someone else to do the work.
Early this year I picked up a 6.1L Hemi with the NAG transmission for another project. So far this looks like it may be less expensive (and easier), even if I get the Altercation K-Member which makes installing a new Hemi easier than trying to fit it around the stock K-member?
For me the fuel tank / EFI fuel pump was the biggest issue. Currently I am using a stock style reproduction tank with a sump and external EFI pump (The pump that came in the EFI kit.) It works fine, and is quiet, but I don't like the way it looks.
I have been thinking of making a custom stainless fuel tank that is a bit deeper than stock, with baffles, internal fuel pump, and fuel cell foam to reduce the fuel sloshing around.
Having 100 lbs of fuel sloshing side-to-side is not good for handling
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: Jerry] #1653122
07/31/14 10:13 AM
07/31/14 10:13 AM
Georgia
Steve Bryant Offline
Georgia
On my Cuda, I went with a 440 since it was an option on the car plus for the 440 are very, very easy to find. Mopar continued to make 440s even until the late-seventies for their vans and trucks. They were also one of the most popular blocks for motor-homes. This means if you need parts they are usually cheap and readily available.
I bought my 6-Pack/forged crank 440 block for $600 and the engine shop had few problems getting it knocked back into shape. The sky is the limit with these engines with the right heads, exhaust, fuel system, etc.
Want to hook up electronic ignition and EFI? No problem.
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: AlexP] #1653123
07/31/14 10:59 AM
07/31/14 10:59 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
440 on a budget 6.4 if you have the funds. As you know it's a little more involved than just an engine swap. With modern cam grinds you can have a very street freindly BB. Top it w/ a six pack if you want max MPGs. I get 15 to and from the track. That's w/ an auto and 3.91's and why do you need to "clone" a 70 500? Does he just want the stripe? Mine is an XH car (came w/ no tail panel and unpadded door uppers and no pockets on the door panels)
Coming soon!!!!
Re: Poll: 446"-470" B/RB or stock 6.4 Hemi [Re: AlexP] #1653124
07/31/14 07:59 PM
07/31/14 07:59 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I have a mild 440 and have driven friends SRT8 6.1's. (Yeah, I know, not a 6.4)
Totally different animals!
Personally? I like the brutal torque of a mildly modified 440/500.
If you're doing a B or RB go with the biggest stroke you can (500+) and Indy EZ heads. You will have more power than you can use in a very mild package. To me, anything over 550 HP on the street is silly anyway.
Ron's combination is perfect for a street/strip car IMO!
Oh yeah, Ive used the solid .528 cam and absolutely loved it in a 440 urged '71 Cuda.
