Page 1 of 3 1 2 3
recent launch pic 4 me #1652976
07/30/14 11:48 AM
07/30/14 11:48 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Johnboy photo took this at notwalk last week and it really shows the spring arch even with slapper bars.
Re: recent launch pic 4 me [Re: Clanton] #1652977
07/30/14 11:55 AM
07/30/14 11:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Tighten up the rear shocks
Re: recent launch pic 4 me [Re: MR_P_BODY] #1652978
07/30/14 12:03 PM
07/30/14 12:03 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I did on the next pass but I don't have a picture but in the picture I posted I went looser by accident on my rancho 9000 shocks to #7 and had a little wheel hop and so when I went back to #5 it launched smooth so the next time out I will go #4 or #3.
Re: recent launch pic 4 me [Re: Clanton] #1652979
07/30/14 12:46 PM
07/30/14 12:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don`t take this wrong but your car needs some work. Way to much rear seperation, too high in the rear and extremely nose heavy..........the first two are easy fixes but the 3rd not so much unless yo get rid of the blower and go n/a as you were questioning........
Re: recent launch pic 4 me [Re: Thumperdart] #1652980
07/30/14 01:09 PM
07/30/14 01:09 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
that car needs a dbl adjustable rear shock for sure
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: recent launch pic 4 me [Re: bigtimeauto] #1652981
07/30/14 01:23 PM
07/30/14 01:23 PM
mi
dirty magnum Offline
mi
do you have an adjustable pinion snuber
Re: recent launch pic 4 me [Re: bigtimeauto] #1652982
07/30/14 01:36 PM
07/30/14 01:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
and change that thing to a caltrac system you if insist on a leaf spring
Re: recent launch pic 4 me [Re: Quicktree] #1652983
07/30/14 01:47 PM
07/30/14 01:47 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Ya the Caltrac would get rid of the arch by not letting the spring have leverage to lift the car.It is on the list.
Re: recent launch pic 4 me [Re: dirty magnum] #1652984
07/30/14 01:48 PM
07/30/14 01:48 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
No I have a truck Dana that has no place for 1.
Re: recent launch pic 4 me [Re: Thumperdart] #1652985
07/30/14 02:09 PM
07/30/14 02:09 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The car is high cuz of the seperation,parked the tires are 1" in the fender at the top.The car may lift more without the blower weight[150#] but I don't need a wheelie and I get traction so that is all I need.Yes things could be adjusted better.The extra weight on the fron I think is equal to about 400 in leverage terms.
Re: recent launch pic 4 me [Re: Clanton] #1652986
07/30/14 02:42 PM
07/30/14 02:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what does a launch like that do to your pinion angle? Seems like a lot of lift...
Coming soon!!!!
Re: recent launch pic 4 me [Re: Mr.Yuck] #1652987
07/30/14 02:44 PM
07/30/14 02:44 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
BINGO!!!The slapper bars are flat at rest and in the pic it looks like they are at 25+* up. I am sure that is killing my 60' also.
Re: recent launch pic 4 me [Re: Clanton] #1652988
07/30/14 03:06 PM
07/30/14 03:06 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
If those springs are s/s spring ditch the slaper bars. way too violent with spring and bar trying to wrap up then you don't have enough shock to control it. If you got wheel hop with the setting at 7 you have something wrong with you whole set up because the highter the no the stiffer it gets. what front shocks do you have, what torsion bars?
JAKES AUTOMOTIVE
Re: recent launch pic 4 me [Re: JAKE68] #1652989
07/30/14 03:20 PM
07/30/14 03:20 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
CE 90/10 front on 90 and .990 t bars for the extra weight up front.The tire only hopped 1 time on 7 setting so I may not have gave it a chance.I have to use the slapper bars or the spring really wind up[ss 3800# ]
Re: recent launch pic 4 me [Re: Clanton] #1652990
07/30/14 03:29 PM
07/30/14 03:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Too many things you`re having to fight to harness that power........fix those things have fun and lower your et`s. Get c-tracs if you`re sticking w/leafs, lower the rear, get good shocks and you just might be surprised but I get it, these things cost $$$$$ which I too am short on these dayzzz.............Good luck man.
Re: recent launch pic 4 me [Re: Thumperdart] #1652991
07/30/14 07:12 PM
07/30/14 07:12 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
The leverage of those bars made your problem worst, you just have enough shock to control this. you make allot of torque with that thing and its probably not a light weight so you have to have the right equipment to help that. I still say ditch bars tighten up shocks to #9 no snubber and try that. we did that to our car and it picked up 60's big time.
JAKES AUTOMOTIVE
Re: recent launch pic 4 me [Re: JAKE68] #1652992
07/30/14 11:01 PM
07/30/14 11:01 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I was told I could use Ctracs with the ss springs and I was thinking of doing that and buy the mono spring later.I think the slapper limits the wind up better than without but I get the same lift of the back end.I will try the shock setting,Thanks!
Re: recent launch pic 4 me [Re: Clanton] #1652993
07/30/14 11:07 PM
07/30/14 11:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Lose the bars and tighten the shocks. If it's hooking already all that extra motion could be used to drive the car forward instead of up. keep tightening until the 60's slow down.
Doug
Re: recent launch pic 4 me [Re: dvw] #1652994
07/30/14 11:11 PM
07/30/14 11:11 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Mike, it's a street car, who cares..lol.. Kidding. You would flip if you knew how much the CalTracs helped my GTX. It even helped the BF Goodrich's stick better. Fran(10secgtx) has a good grip on how they work, so he can help "tune" if you like. He loves helping.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: recent launch pic 4 me [Re: sunroofgtx] #1652995
07/30/14 11:20 PM
07/30/14 11:20 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks Rick.I never did get the letter you sent.
Page 1 of 3 1 2 3
