Re: recent launch pic 4 me
[Re: bigtimeauto]
#1652982
07/30/14 01:36 PM
07/30/14 01:36 PM
Quicktree
that car needs a dbl adjustable rear shock for sure
and change that thing to a caltrac system you if insist on a leaf spring
[Re: Quicktree]
#1652983
07/30/14 01:47 PM
07/30/14 01:47 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Ya the Caltrac would get rid of the arch by not letting the spring have leverage to lift the car.It is on the list.
[Re: Thumperdart]
#1652985
07/30/14 02:09 PM
07/30/14 02:09 PM
Clanton
northern,Ohio,USA
Don`t take this wrong but your car needs some work. Way to much rear seperation, too high in the rear and extremely nose heavy..........the first two are easy fixes but the 3rd not so much unless yo get rid of the blower and go n/a as you were questioning........
The car is high cuz of the seperation,parked the tires are 1" in the fender at the top.The car may lift more without the blower weight[150#] but I don't need a wheelie and I get traction so that is all I need.Yes things could be adjusted better.The extra weight on the fron I think is equal to about 400 in leverage terms. ![](/ubbthreads/images/graemlins/shock.gif)
[Re: Clanton]
#1652988
07/30/14 03:06 PM
07/30/14 03:06 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
If those springs are s/s spring ditch the slaper bars. way too violent with spring and bar trying to wrap up then you don't have enough shock to control it. If you got wheel hop with the setting at 7 you have something wrong with you whole set up because the highter the no the stiffer it gets. what front shocks do you have, what torsion bars?
JAKES AUTOMOTIVE
[Re: Thumperdart]
#1652991
07/30/14 07:12 PM
07/30/14 07:12 PM
JAKE68
Shelby mi.
The leverage of those bars made your problem worst, you just have enough shock to control this. you make allot of torque with that thing and its probably not a light weight so you have to have the right equipment to help that. I still say ditch bars tighten up shocks to #9 no snubber and try that. we did that to our car and it picked up 60's big time.
JAKES AUTOMOTIVE
[Re: dvw]
#1652994
07/30/14 11:11 PM
07/30/14 11:11 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Mike, it's a street car, who cares..lol.. Kidding. You would flip if you knew how much the CalTracs helped my GTX. It even helped the BF Goodrich's stick better. Fran(10secgtx) has a good grip on how they work, so he can help "tune" if you like. He loves helping.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
