Re: Brake pedal to floor-ebrake light on.
[Re: Publicbottle]
#1652955
07/30/14 06:37 AM
07/30/14 06:37 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
The brake light indicates a problem. It doesn't mean the emergency brake is on. It definitely sounds like there is still dinner air in the system.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: GTSDart340]
#1652957
07/30/14 11:31 AM
07/30/14 11:31 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Make sure the bleeder are pointing up.When I did the discs on the 65 I had them pointing down.wasted about a gallon of fluid before I saw my mistake.Ive been doing work for over 40 years.Just got in a hurry and didnt think.Rocky
Chrysler Firepower
[Re: Publicbottle]
#1652958
07/30/14 02:20 PM
07/30/14 02:20 PM
RapidRobert
bleed the MC then all 4 corners then recenter the valve that is turning on the warning light. Yes, air in the system
[Re: Publicbottle]
#1652960
07/30/14 04:09 PM
07/30/14 04:09 PM
therocks
Niles , Ohio
Most remove them and put a spacer between the pad.Then bleed them facing up.Then rebolt them to the brackets.When I had my Imperial with the 4 bleeder discs I had to do that to get them bled.You can back bleed them also.I have a huge looking syringe for back bleeding.Open bleeder and push fluid from the caliper to the master.Cant remember what tool truck I bought it from.Used it a lot on hyd clutches.Rocky
Chrysler Firepower
[Re: Publicbottle]
#1652962
07/30/14 06:27 PM
07/30/14 06:27 PM
therocks
Niles , Ohio
Mine looks like a big hipo syringe.I used it tons at work and it worked probally just as good as that hibuck setup.It has a rubber cap that goes on the end and over the bleeder.I bled many masters and hyd clutch setup with it.Rocky
Chrysler Firepower
