Page 2 of 3 1 2 3
Re: N/A cam for my engine to run N/A [Re: dvw] #1652407
07/30/14 11:23 PM
07/30/14 11:23 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The p to v was .200 int .300 exh at 112 isl
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652408
07/31/14 01:36 AM
07/31/14 01:36 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep, youve got lots of P/V clearence to play with ICL.
Your at 109 now, NA I would try 105 or so. Dont know if I would go much more then that because you may lose to much exhaust overlap ATDC for that scavenging effect that NA motors like with that cam, but that is purely speculative. But, please test away on the dyno for us.
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652409
08/01/14 12:20 PM
08/01/14 12:20 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
I think I may be able to advance my cam and use it but I don't know.OI have been told it is like an old Super stock cam but like I said I have no idea.
.646 int .631 exh
at .050 260 int 269 exh
at .020 291 int 306 exh
int open 21 close at 59
exh open 69 close at 19
112 LSA
Gear?
Converter?
Without any more info, my thought is a single pattern around the same intake duration you have now, but tightened up to a 106-107 LSA. Without the blower, the cam you have now is "bleeding out" the mid-range torque you need to get that heavy beast moving.
Re: N/A cam for my engine to run N/A [Re: all spooled up] #1652410
08/01/14 12:24 PM
08/01/14 12:24 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
get a hold of Dwayne porter
Yep
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: N/A cam for my engine to run N/A [Re: PorkyPig] #1652411
08/01/14 12:43 PM
08/01/14 12:43 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
.646 int .631 exh
112 LSA
Gear?
Converter?
Thanks for you input!I have a 3.73 gear with a 28" tire I could use but not on there now.Do you meen put the cam in[ICL?] with the 112LSA at 106/107 or?I would think the 112 LSA would be better avg hp.I see your point on the exh dur for NA.The convertor is a 5500 with boost and would be maybe 5200 without 9.5"
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652412
08/01/14 02:06 PM
08/01/14 02:06 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
If you were to use your current cam I would advance it to 105 or so. This cam is not ideal for your engine/car combo with out the blower IMO.
I also think you will want a tighter LSA of 106 to 108 Not the 112 LSA that you have in now at a 109 ICL
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652413
08/01/14 05:51 PM
08/01/14 05:51 PM
P
PorkyPig Offline
PorkyPig  Offline
P
Nope, I'm suggesting a new cam ground on 106-107 LSA installed on 102-103 ICL. You need to build some torque, and that blower came ain't the way to do it unless you stick the blower back on.
Re: N/A cam for my engine to run N/A [Re: PorkyPig] #1652414
11/25/14 01:11 PM
11/25/14 01:11 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I ordered a victor 2954 intake and we will see what I can do N/A but I got it to start a parts collection to be N/A and go to some local car stuff.I have my 850 carb to put on.I will work on a cam in due time.
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652415
11/25/14 03:38 PM
11/25/14 03:38 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's going to be hard to run faster then a 6.50 with your combo of parts. The small cubic inches, low stall, and shallow gears are all fighting against a low ET.
I'd change the stall 1st. It will prolly be a better ET gain then a cam. If your stuck on a cam change only I don't think there's a lot to be gained and still keep the lift where you want it.
Can I borrow the blower stuff for a summer?
Re: N/A cam for my engine to run N/A [Re: FastmOp] #1652416
11/25/14 04:10 PM
11/25/14 04:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
MMMMMMaybe for 1 race but not the summer. I will get more N/A parts over time be it a vert or cam.I may do a swap at the track from n/a to boost may be fun or the other way.
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652417
11/25/14 04:59 PM
11/25/14 04:59 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
What is your static compression ratio?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: N/A cam for my engine to run N/A [Re: DusterDave] #1652418
11/25/14 05:09 PM
11/25/14 05:09 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
10.5cr
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652419
11/26/14 02:50 AM
11/26/14 02:50 AM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
Hey if you are interested I have a comp 308r magnum roller I would sell. .262 @ .050 both sides 110 lsa .575 lift with 1.5 rockers. I think this cam would work well with your combo
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652420
11/26/14 04:22 AM
11/26/14 04:22 AM
gregsdart Offline
gregsdart  Offline
Going with a roller cam requires upgrading the entire valve train if you are going to reap most of the benefits. How good are your rockers? pushrods will need to change due to lifter height change. Valve springs will need to be plenty stout, somewhere in the 250+ lbs on the seat, maybe more depending on lobe. It sounds like your combo will want something in the neighborhood of 270 to 275 degrees at .050, probably on a 108 CL or less. The closer you can get to a gross lift of .700 the better. If you have a gross lift of .700 your true max lift will be .700 minus lash (.028?) and also minus compression of parts(.010?) for a total of about .662 net lift, which is just barely above your heads peak flow.
The two things that stand out to me here are your compression, which is fairly low and why I picked the duration and lsa, and stall in the converter. To make this car fly it will be best at or above 5,000 minimum, and closer to 6,000 wouldn't hurt a bit.
If you decide you are willing to stay normally aspirated, then you can cut the heads for more compression and go up in duration to match. It will take a little figuring to see how far you can go with that, but a sharp engine builder can help you out in picking the cam and final compression so you can put the cam where it will be happiest.
Re: N/A cam for my engine to run N/A [Re: gregsdart] #1652421
11/26/14 11:51 AM
11/26/14 11:51 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have a full roller in now,HS rockers,Manton best 3/8 push rods,Pac springs at 280# seat/680# open.The N/A is really for driving on the street to a car show so a perfect combo is not a must have.I may choose to stay N/A later and will try to get parts for that goal.I think my vert will stay over 5K rpm and is 5500 now[9.5" PTC steel stater]
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652422
11/26/14 01:18 PM
11/26/14 01:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I agree w/Greg. Here`s my cam;
Isky solid roller .680-.660 lift 276-281 @ .050 108 lsa installed at about 104-105. Been in the 9`s w/as little as 210 lbs. on the seat and the lobes are gentle enuff to drive for miles. I can hook you up w/Rod at Isky if you`d like.
Re: N/A cam for my engine to run N/A [Re: Thumperdart] #1652423
11/26/14 01:45 PM
11/26/14 01:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for the input!The duration of your cam sounds like a lot,I would get a cam about .600 lift after I test with the cam I have.
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652424
11/26/14 02:28 PM
11/26/14 02:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My duration is a bit much for you but they can hook you up and fwiw almost 8 years on a roller w/one roller rebuild for $ 200.00. I`d go w/as much lift/duration as you need based on head flow and intended rpm range myself. .
Re: N/A cam for my engine to run N/A [Re: Clanton] #1652425
11/26/14 03:10 PM
11/26/14 03:10 PM
The smaller C.I. motors are a little more sensitive to the cam duration. On your deal, especially for the street, I would look at a cam with 255 to maybe 272 duration at .050 and as much lobe lift I could get. Have it ground on 106 to 108 LSA and install it between 102 and 104, depending on the LSA, and let it eat.I always go back to something Joe Alread told me a long time ago, his deal was to work on the fisrt 100 ft. of the track, he said the rest of the track will take care of itself as long as the car leaves hard. I keep that in mind when selecting camshafts, the closer LSA will help the car move a lot harder the first foot than a wider LSA will Been there, done that Let the cam overlap help fill the cylinders, hence Iskys Fifth Cycle advertising back in the day IHTHS BTW, I had one cam that was accidently ground on a 101 LSA, installed at 99 ILC. That cam ended up making the customer very happy, more happy than the other cam that was ground on 110 and installed at 106 intake lobe center
Re: N/A cam for my engine to run N/A [Re: Cab_Burge] #1652426
11/26/14 03:38 PM
11/26/14 03:38 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I just got the intake at the door and it looks like I will do some port matching to Koffels porting but it is just a std port opening.I am going to polish the outside of the intake this winter.
Page 2 of 3 1 2 3
