So, I've got an a904 in my coronet. The car will drive in reverse, but will not drive forward (it just revs like it's in neutral). I've got another a904 that can be installed, but one of the tabs for the converter on the front pump is broken off. So, my question is, what do you think the chances are that the front pump in the transmission in the car is bad, or could I get away with throwing it in the other a904 to have a driving vehicle? Trying to avoid putting too much money in the transmission so I can save up for a manual swap.
