buildanother, therocks, 451Mopar & Mr T2U thanks for your replies!!!
That did the trick, just hook red to one lead and black to the other lead and it works the motor. Switch the leads to reverse the direction.
No need to ground the casing. However I did read somewhere on-line that was the procedure to ground the casing. That's why I relied on the Moparts experts
Also I was able to use a battery charger for testing as long as I had it on the 50 amp setting. 10 amps won't budge it.
Thanks again to you all for your replies.
Bryan
