Re: 426 Wedge Pistons
[Re: Crizila]
#1651668
07/27/14 07:49 PM
07/27/14 07:49 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
10 to 1 trw slugs. Heavy as heck
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: 64MAX]
#1651669
07/27/14 07:59 PM
07/27/14 07:59 PM
Posts: 44,244 Bend,OR USA
Cab_Burge
Those look like the original 1963 415 low compression pistons like was in my 1963 Belvedere had in it from the factory ![](/ubbthreads/images/graemlins/shruggy.gif) What actual diameter size are they on the bottom of the skirts compared to how much are the diameters compared to the wrist pin side location under the bottom rings 90 degrees to the wrist pins ? The TP stands for Thompson Product ![](/ubbthreads/images/graemlins/thumbs.gif) That is one of the comapny that was bought to form TRW in 1961/1963, Thompson Racing Wharehouses, maybe not the proper names for the TRW letters ![](/ubbthreads/images/graemlins/shruggy.gif) Grumpy Jenkins got NHRA to change thier dome hieght specs. for the 1963 415 HP motors do to the dome being to short to make 11.25 to 1 true compression ratio, they will accept either a .090 or .095 dome hieght now. A lot of NHRA M.W. racers I know would look for a set of 1964 415 HP pistons and mill the .120 domes down to the proper blueprint specs. NHRA would accept them for thier 1963 motors ![](/ubbthreads/images/graemlins/shruggy.gif) BTW, them babys you have are really heavy, you can do a lot better now by purchasing a new set from one of the piston companys that make the NHRA acceptable pistons, or better yet have a new state of the art set made for your motor ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Maximus_Wedges]
#1651673
07/28/14 03:15 PM
07/28/14 03:15 PM
dogdays
[Re: 64MAX]
#1651676
07/28/14 11:14 PM
07/28/14 11:14 PM
Cab_Burge
The deck hieght, combustion chamber size and head gasket thickness will determinge the true mechanical compression ratio ![](/ubbthreads/images/graemlins/scope.gif) The OEM 1963 415 HP pistons had a .063 high dome, not sure of the dome volume, 1964 415 HP pistons had right at .120 dome height, same thing on the dome volume sizes ![](/ubbthreads/images/graemlins/shruggy.gif) I've never seen a OEM production Mopar V8 motor, regardless of which size or family, have anywhere close to factory deck heights, combustion chamber size or anythig close to the advertised compression ratio ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) My message is, check yours very closely to get exactly what you want ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Cab_Burge]
#1651677
07/28/14 11:20 PM
07/28/14 11:20 PM
Posts: 6,426 nielsville, minn.
quickd100
nielsville, minn.
The deck hieght, combustion chamber size and head gasket thickness will determinge the true mechanical compression ratio The OEM 1963 415 HP pistons had a .063 high dome, not sure of the dome volume, 1964 415 HP pistons had right at .120 dome height, same thing on the dome volume sizes I've never seen a OEM production Mopar V8 motor, regardless of which size or family, have anywhere close to factory deck heights, combustion chamber size or anythig close to the advertised compression ratio My message is, check yours very closely to get exactly what you want
X2..You are so right Cab, I've never pulled a production engine down that was within 1/2 a point of the advertised spec. The 426 wedge that's on my dyno now is a 413 truck block bored to 4.25 with a set of low compression maxwedge pistons installed. My buddy that screwed it together never checked the deck height, he milled the 516 heads .060 though. With a .021 steel shim head gasket it measured right at 8.44-1.Dave
[Re: 64MAX]
#1651678
07/29/14 04:00 PM
07/29/14 04:00 PM
Posts: 27,383 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
the diameter at 90 degrees to the wrist pin is about 4.245
In a 4.250" bore that will give you .005" wall clearance...that's what the manufacturer intends.
[Re: Cab_Burge]
#1651680
07/30/14 02:15 PM
07/30/14 02:15 PM
John_Kunkel
Rio Linda, CA
Yeah, brain fart...I corrected it.
