Speaker question #1651375
07/26/14 11:11 PM
07/26/14 11:11 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I'm working on a friends 72 Demon with a stock AM radio. The stock speaker in the dash is toast so he wants me to put a pair of 6x9s in the rear deck(which was cut by the PO)just so he can listen to something. I'm wondering what I should look for. I don't want speakers that take a lot of power to drive. Do I want single cone with small magnets? Or can that radio drive something a little better?
Arno
Re: Speaker question [Re: B1arno] #1651376
07/27/14 02:55 AM
07/27/14 02:55 AM
Alabama
BigMoneyLewis Offline
Alabama
I'd recomend just ordering a correct 8 ohm 4x10 reproduction dash speaker from turnswitch.com . Keep in mind ,The factory AM only puts out 2 1/2 watts .
It's a mono radio , so You are going to only be able to run one speaker (unless you use a factory fader switch), and you have to use an 8 ohm speaker , most if not all modern over the counter speakers are 4 ohm and will overheat the radios output transformer.
Greg
gregward@mchsi.com phone 256-852-0955
Re: Speaker question [Re: BigMoneyLewis] #1651377
07/27/14 10:54 AM
07/27/14 10:54 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
will 2 4 ohm speakers in series be o.k.?
Re: Speaker question [Re: can.al] #1651378
07/27/14 12:11 PM
07/27/14 12:11 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
You can run them in series but you'll be splitting that blistering 2.5W. between them.
Re: Speaker question [Re: Dan Halen] #1651379
07/27/14 01:04 PM
07/27/14 01:04 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
This is interesting. I had forgotten about the 4ohm vs 8ohm issue. I didn't realize it could do damage if you you use the 4ohm with a vintage radio. I'm reluctant to install a new 4x10 because it is a SOB to get to. I already had the radio out and the instrument cluster pulled back and couldn't get up in there. That's why I'm hoping to put something in the rear deck.
Re: Speaker question [Re: B1arno] #1651380
07/27/14 01:31 PM
07/27/14 01:31 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
yes, it can cause the radio to over heat similar to a stock coil with no ballast resistor. same theory. just order the correct 6x9's and stop worrying.
Re: Speaker question [Re: mikemee1331] #1651381
07/28/14 09:51 PM
07/28/14 09:51 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
My friend brought over a pair of cheap 6x9s yesterday and I installed them
today in series to keep the impedence at 8ohms. They sound pretty good for
what it is. All is well. Thanks to everyone for their input.
Arno
