Collapsed hydraulic lifter six pack 512 engine #1651151
07/25/14 11:50 PM
07/25/14 11:50 PM
Northern Calyfornua
Sxrxrnr Offline OP
Sxrxrnr  Offline OP
Northern Calyfornua
Just went thru engine a couple months ago because of constant plug fouling because of ill-fitting head to manifold geometry.
Installed Eddy Performer heads, CC Extreme Energy hydraulic roller cam, bee hive springs(150 pound install height), Scorpion roller lifters and Harland Sharp rockers. Except for a pita rear main leak which I took care of, all was well for some 700 miles,,,no plug fouling and car ran great. Initially used Joe Gibbs zinc oil, at 250 miles installed Mobil 1--5 w 30.
Finally got on it thru the gears,,Passon 4 speed,,not going over 5,800 rpm. Next day car felt sluggish with slight miss that developed into a big miss and loud valve train clatter. Pulled spark plugs on noisy side,,,number 6 fouled somewhat. Pulled rocker cover, number 6 exhaust rocker had rocker to valve .25 inch clearance. Pulled lifter, it was stuck in down position some distance from its retainer. Everything else looks just fine.
Have ordered pair of lifters from Scorpion a week ago,,,not here yet so not installed yet.
Question is: What are all possibilities of what went wrong. When engine was down I had it at very throughly cleaned out,,,was already a likely less than 2,000 mile engine,,installed new bearings and rings etc. Running KN filter.
Scorpion says possible gasket material or silicone got into lifter. I don't know how but I guess possible.
I had deliberately chosen Scorpion because reading of like problems with CC lifters and no issues with Scorpion,,,of course CC likely selling orders of magnitude more product than Scorpion might explain that for what it's worth. And now somewhere I read that CC and Scorpion sell the same lifter
I had almost gone with a solid roller,,,wishing that I had now,,,as now a bit wary of what the future will bring. Car is basically street driven with perhaps a few trips to the track in the future.
Looking for thoughts and experiences that others have experienced with hydraulic lifters collapsing. In 50 years never had one fail before,,,but never had one with 150 pounds of installed height seat pressure before either.
Re: Collapsed hydraulic lifter six pack 512 engine [Re: Sxrxrnr] #1651152
07/26/14 01:08 AM
07/26/14 01:08 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
I think I'm having the same issue as this with my wagon ....this is the second set of CC hyd lifters. let me know how the scorpion lifters work
Re: Collapsed hydraulic lifter six pack 512 engine [Re: 10secGTX] #1651153
07/26/14 03:05 AM
07/26/14 03:05 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Why the M1 5/30?
Re: Collapsed hydraulic lifter six pack 512 engine [Re: Sxrxrnr] #1651154
07/26/14 03:45 AM
07/26/14 03:45 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
Seems like if it has debris in the lifter disassemble it and see. If it is something that would not damage anything like silicone put it back together and run it.
Re: Collapsed hydraulic lifter six pack 512 engine [Re: ademon] #1651155
07/26/14 04:46 AM
07/26/14 04:46 AM
Northern Calyfornua
Sxrxrnr Offline OP
Sxrxrnr  Offline OP
Northern Calyfornua
Why the M1 5/30?
. Typo, should have said 5 w 20. Is that worse or is it the Mobil 1 that you question? Running 7 qt road race Milodon, see no reason for heavier oil. Have used Mobil 1 for many years with never an engine failure,,,no reason I know to change I guess,,,except at break in. And with roller lifters, I question that in my mind. Also no windage tray,,,,to much hassle with little if any upside for street engine. Also zero sealer on oil pan(no leaks so far)and when I replace the failed lifter,,,will hopefully have none on intake turkey pan and gaskets.
The stuff doubles the time to do a job,,,and when I pulled intake was disgusting the amount of this stuff that had gotten squozen into very nicely port matched heads and intake ports.
Re: Collapsed hydraulic lifter six pack 512 engine [Re: littleVAL] #1651156
07/26/14 05:00 AM
07/26/14 05:00 AM
Northern Calyfornua
Sxrxrnr Offline OP
Sxrxrnr  Offline OP
Northern Calyfornua
Summit is overseeing warranty replacement with Scorpion...Scorpion wants failed one to check it out. If I had known it was going to take 10 days for Scorpion to drop ship to me,,,I likely would have torn it apart to check it out. Summit themselves only stock 16 lifter sets,,,hence the drop ship or I would of had new ones in a day or 2 if they had them in stock. Gotta love Summit's customer service.
Perhaps Scorpion will give postmortem results. I plan to ax.
Is another reason that I try to not use silicone unless it appears that may be forced to such as damaged or otherwise flawed gasket surfaces.
Re: Collapsed hydraulic lifter six pack 512 engine [Re: Sxrxrnr] #1651157
07/26/14 10:11 AM
07/26/14 10:11 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I wouldnt be surprised if lifters are collapsing and getting hammered. 5W20 seems thin for a hydraulic lifter on a BB with hyd roller spring loads.
Performance lifters are often made with more plunger to wall clearance as a fix to prevent pump-up at high rpm when the effective plunger load on the closing ramps become very small and valving response time is at or above its limits. (Of course this is happening as oil pressure is at its peak).
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Collapsed hydraulic lifter six pack 512 engine [Re: Sxrxrnr] #1651158
07/26/14 10:54 AM
07/26/14 10:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What does the company say for spring pressure.. 150#
is right on the upper limit I think for a hyd lifter
Re: Collapsed hydraulic lifter six pack 512 engine [Re: MR_P_BODY] #1651159
07/26/14 11:28 AM
07/26/14 11:28 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Had the same problem with my 470 build and Scorpion roller lifters. Had a few plungers stick on assembly. Scorpion replaced them. Then after start up and running a bit I had another plunger stick. Gave up and tried Hughes roller lifters. Never had a problem after that. I'll never use Scorpion again. I also bought mine from Summit. Just my
Re: Collapsed hydraulic lifter six pack 512 engine [Re: 70VcodeCoronetRT] #1651160
07/26/14 12:21 PM
07/26/14 12:21 PM
Northern Calyfornua
Sxrxrnr Offline OP
Sxrxrnr  Offline OP
Northern Calyfornua
Born and raised in Lincoln.
As noted earlier had read somewhere that Scorpion/Johnson was same lifter as CC's. I did ask Scorpion tech on this, got a politician's answer.
Re: Collapsed hydraulic lifter six pack 512 engine [Re: Sxrxrnr] #1651161
07/26/14 12:30 PM
07/26/14 12:30 PM
NW Indiana
fbs63 Online content
fbs63  Online Content
NW Indiana
I had the same thing happen on the dyno. Replaced the lifters with Crane hyd. rollers. They pumped right up and never had any more trouble.
Re: Collapsed hydraulic lifter six pack 512 engine [Re: Sxrxrnr] #1651162
07/26/14 05:15 PM
07/26/14 05:15 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Why the M1 5/30?
The stuff doubles the time to do a job,,,and when I pulled intake was disgusting the amount of this stuff that had gotten squozen into very nicely port matched heads and intake ports. [/quote
Just seems light for a old style pushrod/big bearing mill. Problem seems to be the lifter company anyhow
