Heads up defective Cyclone headers #1651111
07/25/14 11:24 PM
07/25/14 11:24 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I had another recent thread regarding a SB dyno test. Seems like a cheap set of headers would do the job. I have a brand new set of cheap Cyclones bought years ago that I bolted up today. I was surprised to find on the pass side the this 3"? crack, looks like it might have been the ERW seam. Might be best to check this area before any warranty expires. I Iig welded the crack, not sure if any internal obstructions developed, but its not a big concern.
Re: Heads up defective Cyclone headers [Re: jcc] #1651112
07/26/14 12:56 PM
07/26/14 12:56 PM
McGregor,Iowa 52157
500ciDuster Online content
500ciDuster  Online Content
McGregor,Iowa 52157
I got some back in the early 80's that collided on the block and oil pan bad enough to keep the flange from sealing on the exhaust ports so I called the company which said they didn't know of any problems but 3 sets later they claimed the jig had been changed and I ended up having a nice fitting set. Then a few year later I bought a set that had never been used for $25 at a swap and the holes drilled about 3/8" low on the port flange so they got welded closed and redrilled.
Mitch
Re: Heads up defective Cyclone headers [Re: jcc] #1651113
07/26/14 01:09 PM
07/26/14 01:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've seen splits like that on lots of tubing.. its
usually how hot the seam welder is set it that causes
it to split but it normally will only happen after
the tubing has been bent
Re: Heads up defective Cyclone headers [Re: MR_P_BODY] #1651114
07/26/14 02:02 PM
07/26/14 02:02 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Makes sense to me, first split I have ever seen, but then I lead a sheltered life.
Also gives me a greater appreciation of why roll bars are not allowed to be made of the stuff.
Re: Heads up defective Cyclone headers [Re: jcc] #1651115
07/26/14 02:34 PM
07/26/14 02:34 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
roll bars are made out of erw tubing all the time and they will pass cert.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Heads up defective Cyclone headers [Re: dusturbd340W5] #1651116
07/26/14 02:41 PM
07/26/14 02:41 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I thought DOM ( a much higher grade processed erw?) was the standard, seems risky, especially if as Mr P says he seen split tubing often. Its basically tail pipe material?
Re: Heads up defective Cyclone headers [Re: jcc] #1651117
07/26/14 03:42 PM
07/26/14 03:42 PM
Kissimmee Fl.
Kissimmee Fl.
a lot of the chassis shops that sell kits are a thick wall erw unless you upgrade to dom.
I got the standard kit from Chassis Engineering and it was erw and my car was certed to run 8.50.
and there is a LOT of rides out there running the same stuff.
Re: Heads up defective Cyclone headers [Re: dusturbd340W5] #1651118
07/26/14 03:52 PM
07/26/14 03:52 PM
Kissimmee Fl.
Kissimmee Fl.
if you look here
http://www.appliedracing.com/tubing-and-plate/tubing-dom---mild-steel---4130/
you will see they have CM/DOM/and mild steel and if you look at there cage kits there standard options are CM or mild steel which is ERW.
Re: Heads up defective Cyclone headers [Re: dusturbd340W5] #1651119
07/26/14 04:15 PM
07/26/14 04:15 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
most places that use welded seam tube will bend it with the seam to the inside of the bend. The lack of stretching the seam helps it not tear
Re: Heads up defective Cyclone headers [Re: prochargedhemi] #1651120
07/26/14 05:51 PM
07/26/14 05:51 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
thats one of those situations where you cant win,if the weld is harder than it should the pipe will have weird wrinkles or wont compress as it should and will therefore stretch the outside radius to much and split from that instead. strange things happen..
Re: Heads up defective Cyclone headers [Re: 1Fast340] #1651121
07/26/14 05:57 PM
07/26/14 05:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Correct.. if the weld is right you can put that seam
anywhere and it'll bend perfectly
Re: Heads up defective Cyclone headers [Re: MR_P_BODY] #1651122
07/26/14 07:21 PM
07/26/14 07:21 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
absolutely correct,just a shame its so darn difficult and expensive finding tubing with good welds these days.
10 years ago any tubing would be good for most anything you could imagine doing to it and then some,these days there is all sorts of isues even doing the simplest of things. almost glad im not working with that anymore
Re: Heads up defective Cyclone headers [Re: 1Fast340] #1651123
07/26/14 07:34 PM
07/26/14 07:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was doing the buying for all the material needed
for the exhaust lab at Chrysler and I bought all of
my tubing from a couple of places(both were US made
tubing) and I bought about 3000' per year.. only once
did I have a issue with bending it and it split at
the seam.. plus old tubing gets brittle from just
sitting around... almost all of what I bought was
416 stainless tubing unless we had a special build
for someone that called for another material.. the
416 is a stainless but is magnetic but has real good
bending properties
