Re: Trans storage question
[Re: 5carguy]
#1651027
07/25/14 11:19 PM
07/25/14 11:19 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
you could store it vertically with a pan under it. Then you could put an electric pump in the pan with a tube going up to the fill plug of the transmission, & a float switch in the pan that would turn on the pump when the fluid in the pan reached a certain level. Good luck, I hope it works out
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: 5carguy]
#1651029
07/26/14 10:56 AM
07/26/14 10:56 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
You could just NOT put oil in it until you are ready to use it. Then it will not leak out. Not a drop.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
