I put a Demon 750 on my stumbling 440 last night. #1650369
07/24/14 09:14 AM
07/24/14 09:14 AM
A certified culture free zone.
74RALLYE Offline OP
74RALLYE  Offline OP
I've got a 440 with low idle vacuum that's always had Edelbrock carbs and an off idle stumble. I just converted it to a 4sp and the stumble made it a real POS to drive. When I had the auto trans I spent many days tuning on the Edelbrock 750 and 800 carbs without getting the stumble completely out. Backing the timing down made the biggest improvement in the stumble, but that also cost a bit of power.
I put a Street Demon 750 on last night and the stumble was gone! I can come out on the clutch at low rpm and pull off with no problems. It's incredible how much better the car is to drive now. I set the carb up with the weakest springs from the set and put the pump shot to max, bolted it on and it was like magic.
Re: I put a Demon 750 on my stumbling 440 last night. [Re: 74RALLYE] #1650370
07/24/14 10:02 AM
07/24/14 10:02 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
And now you know one of the reasons I don't use edelbrocks...
Re: I put a Demon 750 on my stumbling 440 last night. [Re: 74RALLYE] #1650371
07/24/14 10:54 AM
07/24/14 10:54 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You basically went from one of the worst calibrated carbs out there to one of the best.
Congratulations!
Master, again and still
Re: I put a Demon 750 on my stumbling 440 last night. [Re: CokeBottleKid] #1650372
07/24/14 11:00 AM
07/24/14 11:00 AM
74RALLYE Offline OP
74RALLYE  Offline OP
Still there's a couple of wise asses that claim the Edelbrock dead spot on a 440 is all due to the owner's lack of tuning ability. If you have to back the timing way down to band aid it, what have you really fixed?
Re: I put a Demon 750 on my stumbling 440 last night. [Re: 74RALLYE] #1650373
07/24/14 11:16 AM
07/24/14 11:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
or the ones who say bla bla I run 10's with mine, but forget to mention they need TWO to do it. I'd rather have a 30+ y/o DP than a brand new 750Eddy.
Re: I put a Demon 750 on my stumbling 440 last night. [Re: Mr.Yuck] #1650374
07/25/14 11:10 AM
07/25/14 11:10 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Re: I put a Demon 750 on my stumbling 440 last night. [Re: CokeBottleKid] #1650375
07/25/14 11:36 AM
07/25/14 11:36 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Totally agree...unless you rework the entire carb inside/out, the Eddys are POS
Re: I put a Demon 750 on my stumbling 440 last night. [Re: DAYCLONA] #1650376
07/25/14 12:37 PM
07/25/14 12:37 PM
scratchnfotraction Offline
well I have been running a eddy 600 or a 750 for the last 20 yrs. results did vary depending on the engine combo. all street duty daily drivers.
this past weekend I put a 20yr old 6210 spredbore mech double pumper/holley street dominator on.
2x 85 stepside 91 JY 318/whiplash roller cam/NV4500 5 speed/3.55sg 4000# daily driver.
WOWZERS! that thing woke up and made a big improvement in the lowend torque/drivabilty and flat out kicks in when going WOT.
feels stronger/smoother/ and picked up a couple MPG
think I will get a 3310 750cfm mech double pumper for the 88-440 truck and remove the edelbroke.
I don't recall WHY I went to edelbroke in the first place other than it was free??
I always thought holleys were nothing more than gas holes with poor mpg but I am seeing the light 20yrs later.
Re: I put a Demon 750 on my stumbling 440 last night. [Re: scratchnfotraction] #1650377
07/25/14 02:51 PM
07/25/14 02:51 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
A 3310 is a vac secondary carb. Regardless, a very good street carb on a big block Oh and I agree with all the comments on the Edelbrocks...I've fought with a couple...then bolt on a Holley and DONE!!
Re: I put a Demon 750 on my stumbling 440 last night. [Re: 74RALLYE] #1650378
07/25/14 02:55 PM
07/25/14 02:55 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Yep I got hypnotized years ago by a shiny new Edelbrock 1407 and foolishly replaced the good running Holley 750DP that was on the car.
After a few weeks of fighting with the off idle stumble and terrible performance I removed the shiny Edelbrock and sold it to a buddy with a 350 Chebbie and put the Holley back on, lesson learned....
Re: I put a Demon 750 on my stumbling 440 last night. [Re: KillerBee] #1650379
07/25/14 03:05 PM
07/25/14 03:05 PM
dogdays Offline
dogdays  Offline
Let's not get into the usual carb wars.
The important thing about this post is that the Street Demon 750 bolted on and worked RIGHT OUT OF THE BOX!
I want one.
R.
Re: I put a Demon 750 on my stumbling 440 last night. [Re: dogdays] #1650380
07/25/14 03:26 PM
07/25/14 03:26 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Initial timing may play a big part in some stumbles. Not enough and it's worse.
Re: I put a Demon 750 on my stumbling 440 last night. [Re: 74RALLYE] #1650381
07/25/14 03:51 PM
07/25/14 03:51 PM
Georgia
Steve Bryant Offline
Georgia
I also applaud the fact there are bolt-on carb solutions out there that work! There is wisdom in buying something that works the first time. Thanks for sharing!
This year I managed to tame my Eddy into something that does not stumble. For me, it was time-consuming, somewhat more expensive and required several weeks of testing and tuning. I don't blame anyone for buying something out of the box that is better and works the first time and I certainly don't blame the Eddy owner. The problem is most certainly with the stock Eddy carbs.
Re: I put a Demon 750 on my stumbling 440 last night. [Re: Steve Bryant] #1650382
07/25/14 11:18 PM
07/25/14 11:18 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Back in the day, I had a new Carter 750 Comp series AFB on my stock port 906 headed 67' GTX running 12.2-3s in the summer heat at the strip and idling like crap. My buddy brought along a untouched Holley 850dp, which we swapped on to the GTX. For the rest of the day the car ran 11.80s and would idle without dying like the Carter would.
Re: I put a Demon 750 on my stumbling 440 last night. [Re: 6PACMAC] #1650383
07/26/14 01:19 AM
07/26/14 01:19 AM
Sobieski Wi
bee1971 Online work
bee1971  Online Work
Sobieski Wi
Kind Of An Unfair Comparison , Wouldn't You Say
And The Carter Comp 750 Is 100 Times Better Then The Edelbrock 750 Series , And Most Will Say They Are The Same Carbs , Wrong Answer
I Think Most Know How Much I Love The Edelbrock 750 Series COUGH COUGH
However , Honestly The Edelbrock 800 Series AVS Are Pretty Damn Nice Carbs , And Work Well
Click On Link (Moparts Archives) And Look At The Dyno Numbers Comparing The Edelbrock 750 Along Side The Carter 750 Comp And Others
Then Read What He Has To Say About The Edelbrock 750 - Same Things I Have Been Preaching On This Website For Years , And At Times Getting Ripped For It
http://www.moparts.org/Tech/Archive/bb/25.html
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: I put a Demon 750 on my stumbling 440 last night. [Re: bee1971] #1650384
07/26/14 01:53 AM
07/26/14 01:53 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Ya, maybe a little unfair size wise. The Holley had the full choke set up where as the Carter is choke less. Beside the performance increase with the Holley, the car would truly idle. The Carter's and Edelbrocks seem to have sloppier throttle shafts, as in they should be bushed. I think the slop hurts idle quality by allowing a slight vac leak.
Re: I put a Demon 750 on my stumbling 440 last night. [Re: 6PACMAC] #1650385
07/26/14 12:18 PM
07/26/14 12:18 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Its fascinating to hear about the Edelbrock 750 performer. Its an observation voiced by many- not just the mopar crowd. I realize the powers that be at Edelbrock just ignore the shortcomings but I wonder if they at least acknowledge their 750 could use a revision to make it as good as it can be- as good as the Carter 750 from which it is based. Im impressed that someone at Demon recognized the worth of the old Thermoquad and had the guts to bring an improved version of it to the market.
Keep old mopars alive.
Re: I put a Demon 750 on my stumbling 440 last night. [Re: 74RALLYE] #1650386
07/26/14 08:21 PM
07/26/14 08:21 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
So NOW do we want to talk about how long ago I told you to get a Holley?
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: I put a Demon 750 on my stumbling 440 last night. [Re: DaveRS23] #1650387
08/04/14 07:39 PM
08/04/14 07:39 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
Hmmm...I'll assume you're referring to the eddy AFBs as being poorly calibrated slugs and not the AVS Thunder series. I tried to tune the stumble out of a borrowed Carter AFB comp (same as the eddy) and never got it right. Gave that thing back. Now I have an original AVS 750 and aside from needing a rebuild kit due to age...it still runs great. The eddy Thunder AVS carbs should be identical to the original with just a few improvements and more CFM (800). So to be clear...you're talking about the AFB eddys as being junk and not the Thunder series carbs right?? Cuz I was thinking about getting one.
Re: I put a Demon 750 on my stumbling 440 last night. [Re: Dave440] #1650388
08/04/14 09:53 PM
08/04/14 09:53 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I liked the old AVSs. We have all won a lot of races with them. But they were replaced with the ThermoQuads 40+ years ago. And for good reason. The newer CarterBrocks range from poor to fair in their current configurations.
But none of them have the combination of features that the new Street Demons have. Features that have been proven to have real benefits on our engines. Often in Carter carbs. Plus the Street Demons are calibrated much, much better.
It is a former Carter engineer who has played a major role in the development of the new Street Demon. So Carter or Edelbrock could have incorporated these same improvements to their carbs. But they have not. And until they do, there are better choices out there.
Right now, when you objectively compare the features and OOTB calibration of the carbs on the market today, the new Street Demon is THE carb of choice for most of our street cars.
