Re: Found an old ECU....any good?
[Re: Publicbottle]
#1650362
07/24/14 03:00 AM
07/24/14 03:00 AM
RapidRobert
I'm assuming you have a dual terminal (single) ballast. Look in the archives & find out which pin is for the red/green wire on the pentastar connector & ohm that pin to the ECU case & if it has infinity then yes it will work IF it is good. If it has some ohms on the meter then it requires a 4 terminal "dual" ballast system
[Re: Publicbottle]
#1650364
07/24/14 01:50 PM
07/24/14 01:50 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I bet is way better than the ones you can find nowdays
[Re: Paul_Fancsali]
#1650366
07/24/14 02:40 PM
07/24/14 02:40 PM
dogdays
It's an ignition box, it's not an engine control unit (ECU). That implies a computer of some sort.
It's an original unit, stored in the box of its replacement. Chances of it being good are slim, most never got replaced unless they failed.
I don't understand the romance of the Mopar ignition box. Sure, back in the day it was better than points. Sure, it was adequate for nearly all street use. But the original HEI chip was better, when it came out. And, with working CD units, most of them multispark, going for $35 - $100 on the 'bay, why bust your hump trying to get a stock-type ignition box to work?
Or just bite the bullet and buy either Rev-n-nator or FBO's new box that is pretty cool as well, and not just a GM HEI wrapped in a Mopar-type box.
R.
[Re: RapidRobert]
#1650367
07/24/14 03:28 PM
07/24/14 03:28 PM
Posts: 885 alberta
Publicbottle
alberta
Just did this test, looks like i get a bit of resistance between red/green wire pin and the case...so dosnt seem to be a match for my 2 terminal ballast system....
