360 magnum guestion #1650318
07/24/14 01:38 AM
07/24/14 01:38 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
I have a 1996 360 magnum with efi .. my question is what info can you give me about the heads and what will fit this block ? thanks in advance .
Re: 360 magnum guestion [Re: robnbird] #1650319
07/24/14 03:37 AM
07/24/14 03:37 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Replacement heads from EQ are the easiest. Direct bolt on and the air flow as is will walk all over a OE Magnum head. Only disadvantage is they are heavier than OE heads.
RHS x heads also can be had but cost more and the EQs flow virtually the same as cast.
Re: 360 magnum guestion [Re: cudadoug] #1650320
07/24/14 07:31 AM
07/24/14 07:31 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Good source of magnum info here:
http://www.magnumswap.com/
Re: 360 magnum guestion [Re: AAR-B4] #1650321
07/24/14 04:22 PM
07/24/14 04:22 PM
dogdays Offline
dogdays  Offline
Edelbrock makes a really nice Magnum head.
R.
Re: 360 magnum guestion [Re: dogdays] #1650322
07/24/14 04:48 PM
07/24/14 04:48 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Edelbrock is the way to go. I run those on my turbo Dak and have the RHS heads on my 2000 Dak (though didn't run it at the track with them, had stock ones then).
Re: 360 magnum guestion [Re: AAR-B4] #1650323
07/24/14 08:39 PM
07/24/14 08:39 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
thanks for the info .. I have a 68 dart I have been working on for over 1 year and am getting close to choosing a motor . I have a 360 magnum with EFI and if I can wire this to the dart it might be the choice .
Re: 360 magnum guestion [Re: robnbird] #1650324
07/24/14 08:43 PM
07/24/14 08:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hope you got all of the wiring and the computer with it
if you want to stay with the EFI
