Re: 70 gtx steering column
[Re: 70GTXer]
#1650259
07/24/14 02:53 AM
07/24/14 02:53 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I have a console shift car and am replacing the grant wheel with an original woodgrain but when the wheel is mounted there is a large gap between the column and wheel. is there a spacer that can be purchased to fill this gap?
If you need just the black plastic adapter/filler ring, www.tonysparts.com is the source of this repro, IIRC it's $55 w/shipping ...does your steering wheel have 3 drilled holes, 1 in each spoke to accept the ring? to install it, drill 3 holes to receive the ring on the bottom of the spokes, the plastic pins protrude thru the holes, then use a soldering iron to smear the plastic ends down, let cool, your set to go
[Re: DAYCLONA]
#1650260
07/24/14 03:04 AM
07/24/14 03:04 AM
Posts: 18,157 Mass
DAYCLONA
Mass
