Hood mounted turn indicators Charger #1650150
07/23/14 05:46 PM
07/23/14 05:46 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
What do you use to get the wires run thru the hood? Also what direction do you go.. Thru the X brace or straight down? thanks for any info...
Re: Hood mounted turn indicators Charger [Re: JohnH] #1650151
07/24/14 04:42 AM
07/24/14 04:42 AM
Arizona
69rrgrabber Offline
69rrgrabber  Offline
Arizona
This is the only place I found the clips, not sure about the routing, I have the same issue.
http://www.ebay.com/itm/350796481831?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: Hood mounted turn indicators Charger [Re: 69rrgrabber] #1650152
07/26/14 02:22 PM
07/26/14 02:22 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Re: Hood mounted turn indicators Charger [Re: 69CHARGERMD] #1650153
07/26/14 02:39 PM
07/26/14 02:39 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Re: Hood mounted turn indicators Charger [Re: JohnH] #1650154
07/26/14 02:40 PM
07/26/14 02:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
what year ????
Re: Hood mounted turn indicators Charger [Re: TJP] #1650155
07/26/14 03:09 PM
07/26/14 03:09 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
what year ????
Good question! I guess based on his animated gif we are assuming it is a 69/70.
Re: Hood mounted turn indicators Charger [Re: moparfan53] #1650156
07/26/14 04:35 PM
07/26/14 04:35 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
It's a 69 charger.. I finally fished them thru.. Learn as you go.. The hood was on the car, next time do this while the hood is off the car..
