SB fuel pump eccentric #1649799
07/22/14 04:49 PM
07/22/14 04:49 PM
The Sunny Shuswap
dodgefarmer Offline OP
The Sunny Shuswap
Anyone know of a source. Ma isn't able to supply and a search on Mancini came up empty.
Randy
Re: SB fuel pump eccentric [Re: dodgefarmer] #1649800
07/22/14 05:04 PM
07/22/14 05:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Google search finds many sources ? and I found it on Mancini uder the fuel section , mancini is 50 bucks MRE-P4120484
this online source is cheaper.
http://www.moparonlineperformance.com/product-p/p4120484.htm
Re: SB fuel pump eccentric [Re: JohnRR] #1649801
07/22/14 05:13 PM
07/22/14 05:13 PM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
Hughes Engines also has them, about the same price as the Mancini's.
Re: SB fuel pump eccentric [Re: dodgefarmer] #1649802
07/22/14 05:30 PM
07/22/14 05:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: SB fuel pump eccentric [Re: DAYCLONA] #1649803
07/22/14 05:59 PM
07/22/14 05:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mitchell
Re: SB fuel pump eccentric [Re: JohnRR] #1649804
07/22/14 11:40 PM
07/22/14 11:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Mitchell
LOL JOHN, You nailed this one to the wall
Re: SB fuel pump eccentric [Re: TJP] #1649805
07/23/14 02:36 PM
07/23/14 02:36 PM
The Sunny Shuswap
The Sunny Shuswap
Thanks for the reply's. I dug a bit deeper and found 1 online @ $28.95
Thanks again
Randy
Re: SB fuel pump eccentric [Re: dodgefarmer] #1649806
07/23/14 09:32 PM
07/23/14 09:32 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
There are Moly coated and uncoated versions out there. The Moly coated ones should last longer and cut a little friction off also. And Moly probably costs a little more too.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
