tie rods, b& e body #1649758
07/22/14 04:48 PM
07/22/14 04:48 PM
indy
70moparmike Offline OP
indy
have a 70 cuda and the tie rods seem to be to long. they came with the car. anyone know what length they should be from end to end? are the b & e body the same? thanks moparts
Re: tie rods, b& e body [Re: 70moparmike] #1649759
07/22/14 06:23 PM
07/22/14 06:23 PM
More info. The car is together or apart & you have some new ones & the threaded shank is longer than what came out of there or? Generally you want to screw em into the sleeve as far as they will go leaving enough threads so the sleeve can be turned to make the assy a bit shorter later when it is aligned. I'd start by getting the box halfway between it's lock to lock travel and the wheels straight ahead then screw em in till the length is just right so the tapered tie rod ends will go right in the center st link/lbj tapered holes with some threads left on each end so the assy can be shortened a bit further as needed to get the toe in dead on but more info on what's going on/where you are at
Re: tie rods, b& e body [Re: 70moparmike] #1649760
07/22/14 08:43 PM
07/22/14 08:43 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
I just did tie rods (MOOG) on a 70 'cuda. I reassembled them with six threads exposed on each tie rod , the same way the old ones came out. This was very close to the original toe. BTW the tie rods with the RH thread are the outer tie rods. I can can explain that further if you need.
Re: tie rods, b& e body [Re: RapidRobert] #1649761
07/23/14 08:55 AM
07/23/14 08:55 AM
indy
indy
i have the rods screwed all the way together and cant get wheels to come close to straight. i don't know what length they should be for the car is my problem? i don't have any old ones to measure from? thanks
Re: tie rods, b& e body [Re: 70moparmike] #1649762
07/23/14 11:16 AM
07/23/14 11:16 AM
tape measure the length of the sleeves & maybe the poster above could measure his cuz he just did his '70 cuda. overall (C to C) length of the tapered stud centerlines of the tie rod ends screwed into the sleeve(s) would help also
Re: tie rods, b& e body [Re: 70moparmike] #1649763
07/23/14 01:18 PM
07/23/14 01:18 PM
Georgia
Steve Bryant Offline
Georgia
Give me a few minutes and I will crawl under the car and try to measure mine. Not sure I will get a good measurement with them bolted in but I will try.
Re: tie rods, b& e body [Re: Steve Bryant] #1649764
07/23/14 01:48 PM
07/23/14 01:48 PM
Georgia
Georgia
OK, here the photos. They were not easy to take since I don't have a lift but I hope it will help.
Not saying my setup is perfect, but it is aligned and it drives great with no pull and no noises. I rebuild everything with rubber.
I forgot how much the alignment show chewed up my tie-rods...
-Steve
