U Bolts #1649406
07/21/14 10:49 PM
07/21/14 10:49 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
I'm replacing my rear shocks and springs here in a few days and would like to have everything ready to go. I've got the MP super stock springs and a set of KYB shocks. No relocation necessary. What size u bolts do i need to pick up, and are these readily available from autozone/advanced auto?
Thanks!
1968 Plymouth Road Runner 383 4 speed
Re: U Bolts [Re: dobie] #1649407
07/21/14 11:00 PM
07/21/14 11:00 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Steve you can get the good ones delivered to your door from Mancini racing.They carry the OEM type with the knurling and the correct nuts.
Gus
64 Plymouth Savoy
Dana 60
Re: U Bolts [Re: fourgearsavoy] #1649408
07/21/14 11:31 PM
07/21/14 11:31 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Darn. Do you know if summit sells them too? I'm making a trip up there tomorrow after work.
Re: U Bolts [Re: dobie] #1649409
07/22/14 12:09 AM
07/22/14 12:09 AM
Rittman Ohio
Rittman Ohio
I've only used the Mancini racing U-bolts but Summit might have the good ones too.
Gus
64 Plymouth Savoy
Dana 60
Re: U Bolts [Re: fourgearsavoy] #1649410
07/22/14 12:20 AM
07/22/14 12:20 AM
Rittman Ohio
Rittman Ohio
64 Plymouth Savoy
Dana 60
Re: U Bolts [Re: dobie] #1649411
07/22/14 03:50 AM
07/22/14 03:50 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
KYB's are harsh riding and don't have much rebound control. They will make your springs feel a lot stiffer while driving. Use anti sieze on the u-bolt threads and torque them in equal steps. Recheck them after a few miles several times. They always seem to loosen up a little.
Be sure to lube the bushings of the new springs too. I always use synthetic disc brake caliper grease on the bushings, as it won't attack plastic or rubber and has all kinds of good slippery stuff mixed in it.
Here's a pic of my old ones. I ordered mine from a place that makes them for almost anything. They came with the longer bolts, the hardened washers and they fit perfectly. I can look up the name on my receipt, if you're not in a hurry.
Sorry for the delay. Here's the link
http://www.stengelbros.net/U-Bolts_c_23.html
Re: U Bolts [Re: fourgearsavoy] #1649412
07/22/14 07:39 AM
07/22/14 07:39 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Thanks Gus! Im in class all day today in Orrville, and then I'll be flying up to Summit afterwards to pick everything up.
If all goes well, I'll be at our show Saturday with my car.
Re: U Bolts [Re: jbc426] #1649413
07/22/14 07:40 AM
07/22/14 07:40 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Thanks for the tips. I'll pick up some grease while Im shopping and I'll be sure to check things out.
Re: U Bolts [Re: dobie] #1649414
07/22/14 08:09 AM
07/22/14 08:09 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
ANything else you guys can think of that I need but missed?
Ive got one set of these ordered too..
Am I missing something else?
Thanks! bushings
Re: U Bolts [Re: dobie] #1649415
07/22/14 10:28 AM
07/22/14 10:28 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Make sure you have some good penetrating spray.If the springs etc are old they will be rusty.Rocky
Chrysler Firepower
Re: U Bolts [Re: dobie] #1649416
07/22/14 09:18 PM
07/22/14 09:18 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Thanks!
bushings
If you really want to go all out, replace the three bolts that hold the spring on. The rusted old surface of the bolts with some of the rubber permanently stuck to it doesn't allow them to move very freely. Don't over tighten the shackles either.
Re: U Bolts [Re: jbc426] #1649417
07/22/14 10:29 PM
07/22/14 10:29 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Thanks. Got everything picked up. Hopefully all goes well tomorrow then.
Re: U Bolts [Re: dobie] #1649418
07/23/14 01:24 AM
07/23/14 01:24 AM
Rittman Ohio
Rittman Ohio
Give me a call if you need anything tomorrow I'm off all day
Gus
64 Plymouth Savoy
Dana 60
Re: U Bolts [Re: fourgearsavoy] #1649419
07/23/14 07:54 AM
07/23/14 07:54 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Thanks Gus!!!
Re: U Bolts [Re: dobie] #1649420
07/24/14 08:14 AM
07/24/14 08:14 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Well, all went well I think. haha. No major issues encountered. It took about 3-3.5 hrs, but Ive never done this before. I havent driven it yet either. Probably wont be able to until Friday or Saturday. It does sit lower it seems, just by looking at before pictures.
Left side on.
Re: U Bolts [Re: dobie] #1649421
07/24/14 08:15 AM
07/24/14 08:15 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Another.
Re: U Bolts [Re: dobie] #1649422
07/24/14 08:16 AM
07/24/14 08:16 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Both sides on.
Re: U Bolts [Re: dobie] #1649423
07/24/14 08:17 AM
07/24/14 08:17 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Old air shocks. Still held air. I went with KYB 5512's I think. I had bought them about 5 yrs ago when I did the front, but just never got around to installing them. The only "weird" part to all of this are the shocks. The top of them almost, and I mean almost, hits the bottom of the shock mount. They hit until I tightened everything down, then they pulled away ever so slightly. Hopefully this is normal and ok. I double and triple checked that I had the right shock according to rock auto and summit racing.
Re: U Bolts [Re: dobie] #1649424
07/24/14 08:18 AM
07/24/14 08:18 AM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
And the old springs. Both sides had 5 leafs. No clue how old they are. I replaced the shackles too while I was at it.
Re: U Bolts [Re: dobie] #1649425
08/20/14 03:48 PM
08/20/14 03:48 PM
El Pueblo de Nuestra Seņora La...
Ponch Offline
Dancing Queen
Ponch  Offline
Dancing Queen
did you end up using the Summit U bolts? I take it they worked fine?
Gonna be doing a spring swap soon and can't seem to find a good source for the bolts.
