ASH TRAY LIGHT FOR 1966 CHARGER #1649358
07/21/14 06:55 PM
07/21/14 06:55 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
They did not offer it for this car in 1966 but I would like to add one.
Is there a kit available or what can I use from say a 1968 model or other that will work?
Thanks in advance.
Re: ASH TRAY LIGHT FOR 1966 CHARGER [Re: 696pack] #1649359
07/21/14 10:13 PM
07/21/14 10:13 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Check th '66 accessory catalog
http://www.hamtramck-historical.com/1966AccessoriesCatalog-01.shtml
This is the one that fit's '68- '70 B bodies. Pull out the ashtray and see if you have perpindicular slots about 3/8" long and 3/8" apart(actually it's a square hole) . Lamp lead plugs into instrument lamp harness (orange wire) and dims by the instrument lamp dimmer switch.
Re: ASH TRAY LIGHT FOR 1966 CHARGER [Re: Pynzo] #1649360
07/22/14 02:05 PM
07/22/14 02:05 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Thanks, but is there a kit/part I can order new today?
Re: ASH TRAY LIGHT FOR 1966 CHARGER [Re: 696pack] #1649361
07/22/14 02:24 PM
07/22/14 02:24 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
http://m.ebay.com/itm?itemId=360481190307
This one says it fits '66. A little expensive tho-
There's also a listing for a used lamp- $25 shipped. Search mopar ashtray light.
Re: ASH TRAY LIGHT FOR 1966 CHARGER [Re: Pynzo] #1649362
07/22/14 06:05 PM
07/22/14 06:05 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Thank you.
