So after spending nearly $60 buying two of their nifty slip over seals for the pot coupler and getting one installed not even a month ago. Today while servicing the a/c on the van I notice the boot is already cracking and aging quite badly. When I got them in I noticed they were not made out of the updated silicone material that chrysler/aftermarket switched too awhile ago but the same or very similar to the seal material used on the pot coupler seals before the switch to silicone. Was not super impressed to see that but I thought it would be worth the chance, guess I betted wrong.
Save you funds and either ditch the pot coupler altogether or just cuss up a storm while fighting the seal and metal cage retainer into position.
