Re: Pictures of fore/aft locators installed. motor plate [Re: hemi-itis] #1648642
07/21/14 11:13 AM
07/21/14 11:13 AM
fullmetaljacket Offline
Friends, Romans, Country men, lend me your ears.
Mine on the ears to trans cross member bridge. Aluminum heim joints for flex
Hopefully the car doesn't do a Van Gogh number on me.
Re: Pictures of fore/aft locators installed. motor plate [Re: fullmetaljacket] #1648643
07/21/14 12:43 PM
07/21/14 12:43 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Thank you everyone ! I got some ideas now
Re: Pictures of fore/aft locators installed. motor plate [Re: VernMotor] #1648644
07/21/14 01:11 PM
07/21/14 01:11 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
My KOS Demon has brackets on the frame (or K frame) for something like this. I did not get the motor attachments or connectors. Thanks for the pics. Any more?
Anyone fab up the motor side attachments or is that a unique deal?
Re: Pictures of fore/aft locators installed. motor plate [Re: Airwoofer] #1648645
07/21/14 05:29 PM
07/21/14 05:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Basically thats just a L of angle iron or alum angle type
of a deal... if you run it over 3 or 4 bolt holes on
the pan then the L of it hangs down with 1 hole in it
(the buld of the lower L side can be cut off and give
it a nice shape.. the lower hole will have a heim bolted
to it then forward in a thick wall tube or moly tube
with threaded inserts and a L welded to the K to
mount another heim also in the tube
Re: Pictures of fore/aft locators installed. motor plate [Re: PLUM BAD] #1648646
07/22/14 01:59 AM
07/22/14 01:59 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Mine is just like the Plum Bad set up. Stock block. Works well and is very easy to install. Trans is on a rubber pad. So far...since 1986 no breakage.
Re: Pictures of fore/aft locators installed. motor plate [Re: MR_P_BODY] #1648647
07/22/14 02:06 AM
07/22/14 02:06 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I need to make something like these for mine.
I'm still on the stock motor mounts… and wishing the truck would react quicker off the button! LOL
Re: Pictures of fore/aft locators installed. motor plate [Re: Duner] #1648648
07/26/14 12:10 PM
07/26/14 12:10 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
Here is mine. Unfortunately can't see the part that goes in the block.......
