truck valve covers for big blocks
#1648500
07/20/14 10:41 AM
07/20/14 10:41 AM
Posts: 1,413 northeast ohio
hulmule
northeast ohio
I bought a 1978 Ramcharger with a factory 440 and power brakes. From what I see ,to get the valve cover off on the drivers side you have to remove the power brake booster .unless they replaced the booster with a wrong one?? Is there a special valve cover like they used on 67 vettes with power brakes? they ihad a notch on the corner to fit. lil help want to change out gaskets.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: truck valve covers for big blocks
[Re: hulmule]
#1648501
07/20/14 11:24 AM
07/20/14 11:24 AM
Posts: 1,357 central Florida
VL21
central Florida
I can't help on this, mine have all been small blocks. I do know there were some smaller diameter boosters, so it is possible over the years a hard to find BB booster was replaced with the larger diameter small block one ... Do a search, there has been a recent series of posts about this. Good luck! ![](/ubbthreads/images/graemlins/popcrn.gif)
It takes gasoline to interest me.
[Re: VL21]
#1648502
07/20/14 12:12 PM
07/20/14 12:12 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
They used the same stamped steel cover as the rest.
And as long as the smaller diameter booster (its smaller diameter, but longer) is used and not the large diameter pancake booster, there is just enough room to roll the valve cover off the rockers.
Its sort of like playing Operation.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1648503
07/20/14 05:06 PM
07/20/14 05:06 PM
hulmule
northeast ohio
thanks, thinking same thing cause I went thru this on a car. well have to call around and see who has the small one thanks
[Re: hulmule]
#1648504
07/21/14 02:08 AM
07/21/14 02:08 AM
hp383
State of Confusion
The small booster is also used on 3/4 and 1 ton trucks. Big or Small block.
[Re: hp383]
#1648507
07/22/14 08:41 PM
07/22/14 08:41 PM
hulmule
northeast ohio
cool thanks for the pics. I have the larger one on my truck. maybe it got switched out over the years. have to see if I can find one.
