metal (alum or steel) DIY door panels? #1648168
07/19/14 12:28 PM
07/19/14 12:28 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Anyone here made some door panels out of aluminum or sheet steel? I want to make some for my Satellite.
I have the old panels I can use as templates. How are you all attaching yours?
Re: metal (alum or steel) DIY door panels? [Re: Exit1965] #1648169
07/19/14 12:33 PM
07/19/14 12:33 PM
fullmetaljacket Offline
Made mine many years back using the originals as templates. Attached them via small sheet metal screws with a good size thin washer to spread the load. Not too tight or you'll warp the aluminum.
If you really want to get fancy, put the sheet in a bead roll press and roll some beads that resemble something like stock patterns and it will be classy. You have to use a good gauge, not too thin or it looks crappy.
I have now recently went back to A990 light weight panels for the look.
Re: metal (alum or steel) DIY door panels? [Re: Exit1965] #1648170
07/19/14 12:33 PM
07/19/14 12:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Interior or exterior
Re: metal (alum or steel) DIY door panels? [Re: MR_P_BODY] #1648171
07/19/14 03:30 PM
07/19/14 03:30 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Oh yeah, interior..
Re: metal (alum or steel) DIY door panels? [Re: Exit1965] #1648172
07/19/14 04:41 PM
07/19/14 04:41 PM
Az
Crizila Offline
Crizila  Offline
Az
Aluminum on bottom halves. Attached with sheet metal screws.
Fastest 300
Re: metal (alum or steel) DIY door panels? [Re: Exit1965] #1648173
07/19/14 05:18 PM
07/19/14 05:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use alum... and I put a few beads in them to stiffen
it up and for looks(.030 alum)
