6 pak manifold #1647468
07/17/14 01:46 AM
07/17/14 01:46 AM
moscow mills mo
smracing Offline OP
smracing  Offline OP
moscow mills mo
Is there a better manifold than the factory
How much further is needed my red Holley pump will not keep up
Looking to turn 7 to 7500 out of my new block
Carbs and heads are done
rb
block
Re: 6 pak manifold [Re: smracing] #1647469
07/17/14 02:12 AM
07/17/14 02:12 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: 6 pak manifold [Re: sixpackgut] #1647470
07/17/14 02:30 AM
07/17/14 02:30 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: 6 pak manifold [Re: 70AARcuda] #1647471
07/17/14 07:52 AM
07/17/14 07:52 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
http://victorylibrary.com/mopar/weiand-c.htm
The manifold shown in the 2nd set of pics is your best bet. I built a Super Stock 440 with it and it ran quite well. Can't remember where, but one corner wanted a jet way different than the others. A sheet manifold was tried, but the Weiand made more average hp.
Re: 6 pak manifold [Re: LSP] #1647472
07/17/14 12:24 PM
07/17/14 12:24 PM
moscow mills mo
smracing Offline OP
smracing  Offline OP
moscow mills mo
Re: 6 pak manifold [Re: smracing] #1647473
07/17/14 02:32 PM
07/17/14 02:32 PM
I built a 512 C.I. low deck stroker motor several years ago that used a stock type Eddy low deck 6 pak intake and modified 440 carbs., the motor made peak HP(612) at 5600 RPM and made peak torque at 4500(644 ft.lbs)RPM on a DTS engine dyno. I ran that motor in my Street and strip Duster that ran as fast as 10.34 at 134.+ MPH with the six pak on pump gas through the exhuast system and air cleaner on I did a bunch of testing on that car and ended up finding out that the motor like to be shifted at or above 7000 RPM to make the car run its fastest ET and MPH My message is the stock unmodified Eddy dual plane six pak intakes and stock type carbs, jetted to perfection, will make power well above the RPM that they make the most power on a dyno More air and fuel, more power
Re: 6 pak manifold [Re: Cab_Burge] #1647474
07/19/14 01:20 AM
07/19/14 01:20 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Indy cylinder Head makes the ModMan intake. Interchangeable tops. Has shown decent HP improvements over a stock 6-pak.
Re: 6 pak manifold [Re: ProStDodge] #1647475
07/19/14 11:13 AM
07/19/14 11:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what's something like that run?
Coming soon!!!!
Re: 6 pak manifold [Re: LSP] #1647476
07/30/14 12:15 AM
07/30/14 12:15 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Quote from some famous race car driver guy: "That is bad ass!!!!! That is the best intake there is."
I have that intake with the same "jet" size in all eight ports and about 1900cfm of throttle blade.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: 6 pak manifold [Re: 68cuda440] #1647477
07/30/14 12:20 AM
07/30/14 12:20 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: 6 pak manifold [Re: Ari440] #1647478
07/30/14 12:21 AM
07/30/14 12:21 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: 6 pak manifold [Re: Ari440] #1647479
07/30/14 12:23 AM
07/30/14 12:23 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: 6 pak manifold [Re: Ari440] #1647480
07/30/14 12:25 AM
07/30/14 12:25 AM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
Ari ,
they look great especially the Weiand . Which manifold runs best , Weiand or Modman ?
What cubes and RPM are you pulling ?
Have you tried stuffing the Modman ?
thanks,
Tex
Re: 6 pak manifold [Re: Ari440] #1647481
07/30/14 12:25 AM
07/30/14 12:25 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: 6 pak manifold [Re: tex013] #1647482
07/30/14 12:27 AM
07/30/14 12:27 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Ari ,
thanks,
Tex
weiand over the modman
446ci ....... 6500rpms
1.39 9.85 - 137 mph
Re: 6 pak manifold [Re: Ari440] #1647483
07/30/14 12:29 AM
07/30/14 12:29 AM
Sydney,Australia
Sydney,Australia
by much ?
how many cubic inches is your motor ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 6 pak manifold [Re: tex013] #1647484
07/30/14 12:38 AM
07/30/14 12:38 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
by much ?
weaind made more torque
446ci
1.39 9.85 - 137 mph
Re: 6 pak manifold [Re: Ari440] #1647485
07/30/14 01:18 AM
07/30/14 01:18 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
by much ?
446ci
The Weiand runner length is optimized for the 440, it was specifically designed with the 440 in mind. A bigger engine would have the torque peak at a lower RPM with that runner length.
A bigger engine may like the mod man intake better and you could run it with max wedge port sizes.
-Michael
Re: 6 pak manifold [Re: 68cuda440] #1647486
07/30/14 04:15 AM
07/30/14 04:15 AM
Sydney,Australia
Sydney,Australia
Ari,
thanks again
Michael ,
that's what I thought re the Modman . I have a dual quad Modman (stock port)that wasn't quite right for my 450ciRB but should work nice on top of a stroker
Tex
New best MPH 130.32
Re: 6 pak manifold [Re: 68cuda440] #1647487
07/30/14 11:35 AM
07/30/14 11:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
by much ?
446ci
-Michael
Anybody try one w/ Stage VI heads? does the extra 3/4" make a difference? (talking Stock stroke 440 and small solid roller cam)
