6 pak manifold
#1647468
07/17/14 01:46 AM
07/17/14 01:46 AM
Posts: 89 moscow mills mo
smracing
moscow mills mo
Is there a better manifold than the factory How much further is needed my red Holley pump will not keep up Looking to turn 7 to 7500 out of my new block Carbs and heads are done rb block
Re: 6 pak manifold
[Re: 70AARcuda]
#1647471
07/17/14 07:52 AM
07/17/14 07:52 AM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
http://victorylibrary.com/mopar/weiand-c.htm
The manifold shown in the 2nd set of pics is your best bet. I built a Super Stock 440 with it and it ran quite well. Can't remember where, but one corner wanted a jet way different than the others. A sheet manifold was tried, but the Weiand made more average hp.
Re: 6 pak manifold
[Re: ProStDodge]
#1647475
07/19/14 11:13 AM
07/19/14 11:13 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Indy cylinder Head makes the ModMan intake. Interchangeable tops. Has shown decent HP improvements over a stock 6-pak.
what's something like that run?
Re: 6 pak manifold
[Re: Ari440]
#1647480
07/30/14 12:25 AM
07/30/14 12:25 AM
Posts: 2,462 Sydney,Australia
tex013
Sydney,Australia
Ari , they look great especially the Weiand . Which manifold runs best , Weiand or Modman ? What cubes and RPM are you pulling ? Have you tried stuffing the Modman ? thanks,
Tex
Re: 6 pak manifold
[Re: Ari440]
#1647483
07/30/14 12:29 AM
07/30/14 12:29 AM
tex013
Sydney,Australia
by much ? how many cubic inches is your motor ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: 6 pak manifold
[Re: tex013]
#1647484
07/30/14 12:38 AM
07/30/14 12:38 AM
Posts: 5,618 long island NY
Ari440
long island NY
by much ?
weaind made more torque
446ci
1.39 9.85 - 137 mph
Re: 6 pak manifold
[Re: 68cuda440]
#1647486
07/30/14 04:15 AM
07/30/14 04:15 AM
tex013
Sydney,Australia
Ari, thanks again Michael , that's what I thought re the Modman . I have a dual quad Modman (stock port)that wasn't quite right for my 450ciRB but should work nice on top of a stroker
Tex
Re: 6 pak manifold
[Re: 68cuda440]
#1647487
07/30/14 11:35 AM
07/30/14 11:35 AM
Mr.Yuck
Brookeville, Md
by much ?
446ci
The Weiand runner length is optimized for the 440, it was specifically designed with the 440 in mind. A bigger engine would have the torque peak at a lower RPM with that runner length.
A bigger engine may like the mod man intake better and you could run it with max wedge port sizes.
-Michael
Anybody try one w/ Stage VI heads? does the extra 3/4" make a difference? (talking Stock stroke 440 and small solid roller cam)
