Re: 03 Ram questions
[Re: Rhinodart]
#1647383
07/17/14 01:58 AM
07/17/14 01:58 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I do find it a little odd that the O2 fuse has NO power until the engine is running. It has a P0137 code (low voltage bank 1 sensor 2) It also has a misfire code on #1 P0301 caused by a bad coil (replaced) which could also trip the O2 code. The data port is dead too so I can't even dump all the codes and see what comes back. Well now that it has a history of electrical problems, do you smell smoke...? Kevin
Re: 03 Ram questions UPDATE
[Re: Twostick]
#1647387
09/08/14 01:28 AM
09/08/14 01:28 AM
Posts: 859 Southeast Pa.
SALEM1912
Southeast Pa.
Have you removed any wires from the fuse box. Sometimes terminal spread and even though the fuse check good it's not making contact with the terminal. Just a thought. Any recent repairs?
