Indy 440 EZ-1 flow numbers?? #1647355
07/16/14 08:16 PM
07/16/14 08:16 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
In a couple weeks i am going to get my ez-1 heads worked over and flowed. Anyone had this done? What are some realistic numbers to look for? We are going to flow them before any thing is done then just see what we can do to improve them.
Re: Indy 440 EZ-1 flow numbers?? [Re: bobs69] #1647356
07/16/14 09:09 PM
07/16/14 09:09 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
No idea, but I have already run a 9.81 on pump gas with OOTB EZ-1 heads....
And last week with a different carb, I now have a new best 1/8th mile pass of 6.14 at over +111mph, which they tell me translates to a 9.64 in the 1/4...But is still not proven by me running that quick in the 1/4, but we will see.
Re: Indy 440 EZ-1 flow numbers?? [Re: bobs69] #1647357
07/16/14 09:14 PM
07/16/14 09:14 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Nick over @ Compu-flo did mine last year if I remember correct they flowed 346 int and 236 on the exh . I have to find my sheet.
They work good either way though
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Indy 440 EZ-1 flow numbers?? [Re: bobs69] #1647358
07/16/14 10:41 PM
07/16/14 10:41 PM
AndyF Offline
AndyF  Offline
They work well enough to make 900 hp on my 514 without using an offset rocker arm. Talk to Dwayne at Porter Racing Heads about head work. He can take care of anything you need done.
Re: Indy 440 EZ-1 flow numbers?? [Re: AndyF] #1647359
07/16/14 10:49 PM
07/16/14 10:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Are these max wedge ports? I`m going to be looking at a new top end early next year to replace my standard port eddies and don`t want an exotic valve train to mess with. Any flow sheets Andy?
Re: Indy 440 EZ-1 flow numbers?? [Re: Thumperdart] #1647360
07/16/14 11:26 PM
07/16/14 11:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought my EZ heads from Dwayne Porter and all he did was clean up the bowls and make sure the valve job was good. And he just opened up the end of the intake ports to max wedge size. He told me they all have max wedge ports but the basic EZ heads size the ports down to standard 906 size ports at the opening of the ports. About 1/4 to 1/2" deep is standard size and then they are max wedge size for the rest of the ports. So he just opened the ports up about 1/2" deep to max wedge size. He flowed them and they flowed 329 at .600 on the intakes. They work fine for my combo and have been trouble free. Ron
Re: Indy 440 EZ-1 flow numbers?? [Re: 383man] #1647361
07/16/14 11:31 PM
07/16/14 11:31 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: Indy 440 EZ-1 flow numbers?? [Re: Thumperdart] #1647362
07/16/14 11:55 PM
07/16/14 11:55 PM
AndyF Offline
AndyF  Offline
My heads are MW ports but they use the stock rocker arms. There is another version of the EZ heads that use the 440-1 offset intake rocker arms but I didn't step up to those. My heads flow a little over 360 cfm on Dwayne's bench.
Re: Indy 440 EZ-1 flow numbers?? [Re: AndyF] #1647363
07/17/14 12:01 AM
07/17/14 12:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My brother traded a guy for a set of the big EZ heads that use the offset rockers and have the 325cc intake ports. Mine are the basic that use the standard rockers. Thats one reason I used the basic EZ's as they use the standard rockers and the exh port is not raised. Ron
Re: Indy 440 EZ-1 flow numbers?? [Re: AndyF] #1647364
07/17/14 12:03 AM
07/17/14 12:03 AM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
The barracuda i have went 6:06 @ 113 in the eighth mile with these heads @ 3200 pound. We are just going to see if we can gain anything
Re: Indy 440 EZ-1 flow numbers?? [Re: AndyF] #1647365
07/17/14 12:05 AM
07/17/14 12:05 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thankxxx Andy............those numbers are on par w/my flow/power and low 9`s et goal..............
Re: Indy 440 EZ-1 flow numbers?? [Re: AndyF] #1647366
07/17/14 12:27 AM
07/17/14 12:27 AM
tboomer Offline
tboomer  Offline
Nice! What is the rundown on that Andy? Can you post a dyno sheet? Parts combo? Thanks! Ted
Re: Indy 440 EZ-1 flow numbers?? [Re: tboomer] #1647367
07/17/14 01:04 AM
07/17/14 01:04 AM
Chester, VA
tobnHisglory Offline
Chester, VA
Tboomer, here is a link to an earlier 505" version of Andy's motor in Mopar Muscle. It has since been rebuilt and optimized.
http://www.moparmusclemagazine.com/techa...er/viewall.html
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: Indy 440 EZ-1 flow numbers?? [Re: tobnHisglory] #1647368
07/17/14 10:07 AM
07/17/14 10:07 AM
tboomer Offline
tboomer  Offline
Thanks for the link! Saw the component list but no dyno sheet.
Re: Indy 440 EZ-1 flow numbers?? [Re: tboomer] #1647369
07/17/14 01:48 PM
07/17/14 01:48 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
We are getting ready to put the motor back in the 'cuda. I had the heads opened up by Compu-Flow. Nick managed to get 343 / 242 @ .700 with a full port job. The heads originally had bowl work and flowed 326 / 229 @ .700. They performed well 10.95 @ 3450 with me. 500 ci.
Re: Indy 440 EZ-1 flow numbers?? [Re: JACK1440] #1647370
07/17/14 04:33 PM
07/17/14 04:33 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I have the 295 CNCd version and had Dwayne Porter handle the valve job, clean up etc. They flow 340@.600 and 355 @.700 with max wedge ports and stock rockers.
2 kids and a dog
Re: Indy 440 EZ-1 flow numbers?? [Re: JACK1440] #1647371
07/17/14 10:03 PM
07/17/14 10:03 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Jack dont you mean 9.95 ? Ron
Re: Indy 440 EZ-1 flow numbers?? [Re: 383man] #1647372
07/17/14 10:18 PM
07/17/14 10:18 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
Thanks Ron.... 9.95. Hoping for 9.70s...
