Re: battery kill switch diagram
[Re: littleVAL]
#1647074
07/18/14 01:55 AM
07/18/14 01:55 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you don't like the charge line hot all the time you can use a large diode or wire direct to the battery and put a solenoid that is activated by voltage after the kill switch so when you turn off kill switch it kills solenoid and with it wired to the battery there will be no charge voltage to keep it alive. The reason the disconnect is on the positive instead of negative side is some alt. will full field and fry things when you remove negative. You can do the same thing on the ground side to by putting the ground through a solenoid and activating it on the output side of the disconnect the same way as the charge line you just need to get a solenoid that has two wires so you can run the other side to the battery side ground or it will not turn back on. I used to do rv repair they do all kind of disconnects and charge diodes on them. I just realized that big cube put a diagram that shows it perfectly.
If you are really worried about it being hot you can put a 100 amp fuse at each end of the alt output lead... how many times have you EVER HEARD of that line shorting out... every production car is hot.. I dont waste my time with all those added things that can fail and leave you hanging
[Re: littleVAL]
#1647076
07/20/14 02:21 AM
07/20/14 02:21 AM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Hi All, So me and a bud of mine tried to figure out what's going on here and we made some headway, but are still a little stumped. We've called it a night and will try again tomorrow, but here's a pic of how my alt is wired up with info id'ing the wires. We went from testing the kill switch to making sure grounds were good to making sure all the wiring was secure. We are now thinking there might be something messed up on the dash side of the bulkhead, but wanted to see what input we'd get before going further. In the image, I id'ed the wired coming to/from the alt and hope to get some input. Again, I thank everyone for their assistance. Dave
[Re: 67dodge67]
#1647080
07/20/14 02:54 AM
07/20/14 02:54 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I use a continuous duty relay in mine to kill alternator when the switch is off.
Did exactly what you show here, checked it twice as well... hit the switch and it remained running. Not sure where to go from here... bottom line is I need to have it work before I go to the track; yep tech said ya gotta have one with a trunk mounted battery. Nothing has changed (factory wiring harness, etc.) from day one when I got the car. Will see what I can find for info, greatly appreciate your help here.
As shown put your Alt wire to the relay, and put your ignition /bulk head feed at the Moroso cutoff switch feed.
Get the ignition feed off the alt output and feed it from the Moroso cut off switch as in BigCubes diagram. Then your good to go.
[Re: MR_P_BODY]
#1647081
07/20/14 04:07 AM
07/20/14 04:07 AM
Sport440
Canton, Ohio
Mike, the positive post at the starter is hot, straight from the bat/cutoff switch when on, so I can see why the alt output is ran there.
EDIT, the above is incorrect. The Alt output needs to go to the Dead side of the rely as in BigCubes Diagram.
[Re: Sport440]
#1647082
07/20/14 11:17 AM
07/20/14 11:17 AM
MR_P_BODY
The big (red) alt wire has to be on the battery side of the master.. if it goes to the starter the alt is supplying power when the master is off... the black lead he has is also a problem.. it will supply power to the ignition
[Re: 67dodge67]
#1647085
07/23/14 02:13 AM
07/23/14 02:13 AM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Hi all, Got it all sorted out and all is good. Kill switch works mint! Used the image from bigcube and had to do a few things different due to what was done to the car previously... didn't find that out until digging deeper into it... but she's wired up correctly, everything shuts off when the master is thrown, all is good! Thanks again to all who chimed in and helped! Thanks!! Dave
[Re: 67dodge67]
#2602501
01/06/19 05:31 PM
01/06/19 05:31 PM
Posts: 47 S.E. Michigan
TruPerformance
S.E. Michigan
Can any tell me what do you run on the small lug of the relay in Bigcube’s diagram? The rest is clear, and I am in process of doing this, I just don’t see why I need another wire from the small lug? Any help is appreciated!
1963 Belvedere (mine) 1969 Roadrunner (wife's)
[Re: TruPerformance]
#2602516
01/06/19 06:10 PM
01/06/19 06:10 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Can any tell me what do you run on the small lug of the relay in Bigcube’s diagram? The rest is clear, and I am in process of doing this, I just don’t see why I need another wire from the small lug? Any help is appreciated! I only see one small wire, unless there is another diagram somewhere. The one wire triggers the relay when the kill switch is turned on. This way the wire to the alternator is only hot when the kill switch is on.
[Re: justinp61]
#2602525
01/06/19 06:24 PM
01/06/19 06:24 PM
TruPerformance
S.E. Michigan
On the diagram and my solenoid also, there are three lugs. One side is the power from the master disconnect, the other large lug is where you run the alternator wire to. But the diagram shows a line to the third small lug and ties it to “power to car”. Just not sure if I need to do anything with that small lug? Seems like it is not necessary?
#2602530
01/06/19 06:36 PM
01/06/19 06:36 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Without power to the small lug the solenoid won't close and complete the alternator circuit.
With the switch ON, power from the ON side of the switch supplies power to energize the solenoid and complete the alternator circuit; with the switch OFF the solenoid is de-energized and the alternator output is removed from the system.
This prevents the alternator from supplying power to the car and defeating the purpose of the kill switch.
[Re: John_Kunkel]
#2602535
01/06/19 06:45 PM
01/06/19 06:45 PM
TruPerformance
S.E. Michigan
OK, I thought the solenoid would open when the disconnect switch was turned on, since it supplied power to the main lug opposite the alternator wire. So, you’re saying this just needs power from the disconnect, not to wire to the front of the car? That is different than the diagram. Appreciate the help folks!
[Re: 67dodge67]
#2602844
01/07/19 12:17 PM
01/07/19 12:17 PM
TruPerformance
S.E. Michigan
It makes complete sense now!!! I got a couple wiring changes to clean up under the hood now and I’ll be all set. I like the idea of using a key’ed source to power the solenoid. Appreciate the help!!!
[Re: 67dodge67]
#2602943
01/07/19 02:40 PM
01/07/19 02:40 PM
Posts: 740 WA
JD Dart
WA
I use 75 amp relay and 100 amp C/B for all power Alt is not hot without the car running needs oil pressure.
best so far 8.53 @ 158.59 MPH 60'1.240
