Power brake boosters; vacuum range
#1645892
07/13/14 09:57 AM
07/13/14 09:57 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang...
I was curious on the range of vacuum required for normal/safe operation of the power brake booster ( bendix ). Yesterday I got the 426 HEMI running and I'm drawing about 10-11 inches of vacuum. I am going to try and fine tune the timing and fuel-air mixture some more.......
Cheers, Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Power brake boosters; vacuum range
[Re: hemi68charger]
#1645893
07/13/14 12:16 PM
07/13/14 12:16 PM
RapidRobert
iirc I heard 12 or 14 but I did not pay attention since I never run PB
[Re: Hemi ragtop]
#1645895
07/13/14 03:22 PM
07/13/14 03:22 PM
hemi68charger
Houston, Tx
Just spoke with a friend of mine. He is old-school Mopar and former car-chief for Michael Waltrip. He echoed what a lot have already mentioned over the years and I probably need to go down the same path. I am using a Chrysler electronic distributor as my trigger for the MSD-6A ignition. He proposed I remove the springs, install both light springs, bee-bee the vacuum line ( I want to keep the OEM look ) and set the total degrees at about 32 as a starting point. I mentioned this will gain my more initial timing and hence vacuum. If you have 17, I should get more than 11...... Now that I have the motor started, the next phase is test and tune for THIS particular motor...
