Re: voltage reg?
[Re: TJP]
#1645695
07/12/14 08:49 PM
07/12/14 08:49 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Make sure the reg is grounded good also.My old Ram Charger would shake loose.Then it would overcharge.I finally used larger bolts.Rocky
Chrysler Firepower
Re: voltage reg?
[Re: dirtybee]
#1645696
07/12/14 11:56 PM
07/12/14 11:56 PM
RapidRobert
I've yet to see an electronic reg that goes bad part time. Does the RPM change when the voltage jumps? this might be a stretch but I'd confirm the voltage with another meter. Other than that I'd think alt/brush issue/a wire going open/closed intermittently or grounding out somewhere if its in the green wire circuit (way less likely). Keep us posted
Re: voltage reg?
[Re: RapidRobert]
#1645697
07/13/14 10:13 AM
07/13/14 10:13 AM
therocks
Niles , Ohio
RR a bad ground at the reg will cause the gauge to go hi part time.My Ram did it and drove me nuts for a while.It was night and I was plowing.Was going to change reg and when I went to unhook it it was loose.Tightend and all was back to normal.I agree most always the reg will work or not.They usually just quit charging though.Rocky
Chrysler Firepower
