Electric water pump recomendation
#1645511
07/11/14 10:59 PM
07/11/14 10:59 PM
Posts: 310 western Ky
CraigS
western Ky
Hello every one, Well,just drove to the track tonite and didn't get to race because my Moroso water pump drive quit working.The motor just wont turn til you move it with your hand ,then it turns very slowly,and gets hot quick.This is the second motor,and this ones only been on there for less than 2 years.I want to step up to an electric water pump,the kind that goes into the stock housing,and I see three brands.The Mezierre, the Proform,and the moroso.I am pretty unhappy with Moroso right now,any one have experience with the proform? The Mezierre looks really nice,and they have an HD that flows 42 gpm vs the Proforms 35gpm rating,and its only 20 dollars more.Any horror stories about Mezierre stuff???How about Proform???Thanks guys. This is for dragstrip only 440 bracket car w/iron 906 heads .No street use.
Re: Electric water pump recomendation
[Re: CraigS]
#1645517
07/12/14 12:16 AM
07/12/14 12:16 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Thumper,you must live a charmed life ,aren't you the guy that's never broke your 8 3/4 rearend running 9 second quarters for 50years???
you know I am just kidding..hahaha
I must live a charmed life also My pump motor has been on a long time and my 8 3/4 is still alive with 1.38 - 1.40's in the 60' @ 3325# Stock caps and it's not back braced either
[Re: CraigS]
#1645519
07/12/14 12:37 AM
07/12/14 12:37 AM
roadhazard
Akron, Ohio U.S.A.
My first one was a Mr Gasket and it gave up the ghost early on in it's life. Learned to leave the belt scary loose helps them live longer. The Moroso motor was defiantly a higher quality than the other.
[Re: roadhazard]
#1645522
07/12/14 02:40 AM
07/12/14 02:40 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Absolutely. If you have any belt tension , you are pretty close to too tight.
[Re: CraigS]
#1645529
07/15/14 10:22 AM
07/15/14 10:22 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Meziere. Been running the same one on my hemi since 2006.
