Re: who cnc ports heads?
[Re: 1baddart]
#1644226
07/08/14 08:10 PM
07/08/14 08:10 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
IMO... Waiting to get ahold of Bob at Modern will be worth it.
[Re: HEMIDARTS]
#1644228
07/09/14 12:00 AM
07/09/14 12:00 AM
Posts: 4,696 On the parachute mount
n20mstr
Modern, or just go through Scott Brown, you can get him buyracingparts.com
Scott does all my heads intakes and cams, great results for me !
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#1644229
07/09/14 12:10 AM
07/09/14 12:10 AM
B3422W5
Portage,michigan
Doesn't Scott use Modern himself? I would just deal direct with Modern
[Re: 1baddart]
#1644233
07/09/14 11:04 AM
07/09/14 11:04 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
You might try email............. MODERNCYL@aol.comMark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1644234
07/09/14 11:34 AM
07/09/14 11:34 AM
Posts: 52,972 Romeo MI
MR_P_BODY
MODERNCYL@aol.com
Mark
Or PM him on here.... he usually sends back my PM in a day or so... but I havent seen him on here lately
[Re: n20mstr]
#1644236
07/09/14 01:01 PM
07/09/14 01:01 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Yes he does, but I'm saying go through Scott is sometimes easier than dealing with modern. That's all, I consider my 440-1 to be the best ones I've seen, can't argue with 5.30's @ 132 , 3350lbs and a "street" roller cam from Scott.
That's how I do it. Never had a problem.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: n20mstr]
#1644237
07/09/14 01:18 PM
07/09/14 01:18 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
Do you have flow data on those heads? I would like to see how they compare to my CNC 325s.
[Re: Airwoofer]
#1644238
07/10/14 12:16 AM
07/10/14 12:16 AM
n20mstr
Yes I have a flow sheet, says they go 385 on the intake on a 4.375 bore
[Re: AndyF]
#1644240
07/10/14 06:56 AM
07/10/14 06:56 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Anybody hear of, or use Heads up in Dayton Oh? They're a few miles away from Kammer&Kammer
**Photobucket sucks**
[Re: 1baddart]
#1644241
07/10/14 10:59 AM
07/10/14 10:59 AM
Posts: 2,177 ill
dennismopar73
ill
Looking to have my 440-1 heads cnc ported. I've called modern several times with no luck. Who else does it? What's the going rate for cnc porting?
Question would be why? How fast you running now? How fast do you exspect to run ? Are you just porting head no other changes? Reson for asking i have seen stock heads run eddie jr run Ported eddies run , and cnc ported jr heads run In several combos from 474 motors to 540 In various cars wieghts Dynos prove nothing to me as to many have known to be not reliable As well as many flow benches What i would rather see is some one that has actually taken thier heads Take stock ones off run them. Put set of thier so call ported stuff Make no other changes see what the actual pick up really is in the real world
