Challenger exhaust heat shield mounting #1644182
07/08/14 06:08 PM
07/08/14 06:08 PM
Mn, USA
3
340ShakerR/T Offline OP
Mn, USA
I have gotten to the point of mounting my exhaust heat shields. It looks like there are four mounting holes. The front and outside holes appear to be pretty straight forward. Small slots and body bolts that screw into the frame rail. What is required for mounting the rear? There are two large slots that fit over two studs. I cannot find any nuts/washers in my parts box that are large enough for these two slots. What am I missing something? Thanks.
Re: Challenger exhaust heat shield mounting [Re: 340ShakerR/T] #1644183
07/08/14 06:20 PM
07/08/14 06:20 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Rear "U" shaped exhaust tip hangers/rubber insulators and inside trunk brackets.The inside brackets have the studs on them that go thru the 2 oblong holes on the end of the shields.
Re: Challenger exhaust heat shield mounting [Re: 44D6PAKCUDA] #1644184
07/08/14 06:38 PM
07/08/14 06:38 PM
Mn, USA
3
Mn, USA
OK, makes sense. I will see if I can find them. Thank you.
Re: Challenger exhaust heat shield mounting [Re: 340ShakerR/T] #1644185
07/08/14 06:53 PM
07/08/14 06:53 PM
Mn, USA
3
Mn, USA
Found them, right were I left them. Thanks again.
