So here's the story.
About 3 years ago, I was on a deserted piece of asphalt, and layed into the Dart from a slow rolling start. Hit 6000 rpm right now. Nothing out of the ordinary.
Right away it started to pop, sputter, etc... WTH?? At this point in time, I didn't have a garage, just a rented storage unit. I was able to drive it there and park it. At low rpm cruising, it was fine. Get on it, and the sputter, popping and a rattling sound was there. Didn't have to get on it hard really, just a load on the engine and the symptoms came back
Life then gets in the way.
Then a garage gets built.
Fast forward to now.
I drained all of the old gas out and pulled the carb. Cleaned out the bowls and passages, reset/rechecked settings, etc.
Next I pulled the intake. Nothing out of the ordinary to be seen, but decided to pull the valve train as well and check. No bent pushrods, broken rockers, or collapsed lifters (I was kinda hoping to find a collapsed lifter). Valve springs all look good and at the same height and alignment.
Buttoned it all back up and gave it an oil change. Pulled plugs to look for possible mechanical damage. Nothing.
Also checked the bolts on convertor. Nothing loose.
Car starts fine. Idles fine (ish). Rich alittle but oh well. The popping and sputtering is now gone. At low rpm, say up to about 2200rpm, with light load on the engine, everything seems ok. Get into a little or drive up a steep hill, and I can hear what I can only describe as a rattle. Definitely not a knock. To be honest, ALMOST sounds like detonation, OR a collapsed or damaged lifter. When I checked the lifters, I could not compress them at all by hand using a pushrod on the plunger.
Here's a general breakdown of the set-up.
493 RB
Stock RPM heads
Roller tip rockers
Smith Bros pushrods
MSD 6AL, and pro billet distributor
11.1-1 calculated compression
BIGS 850 DP
Now. The best gas to be found here is 91 octane. So I can see detonation
maybe , but it was fine before this incident. Timing is 20 initial, and I think high 30s all in by 2500 rpm (forgot to check total timing
The only other thing that I can think of to check, are the springs on the distributor maybe??? Maybe one broke or fell off, and once the rpm gets to a certain point, the timing goes through the roof, causing detonation?? Or am I just grasping straws on this one.
I am currently working offshore at the moment, so I can't actually do anything for 2 weeks,but I am ALL ears when it comes to suggestions on what to check for next.
The noise sounds too "tinny" I think to tear into the bottom end. Is there any chance it could be transmission related?
Thanks for reading.
codfish
