1972 Dodge D100 Steering Wheel compatibility? #1643906
07/08/14 01:00 AM
07/08/14 01:00 AM
Australia
Adam_Downunder Offline OP
Australia
Hi All,
I've got a '72 Dodge D100 Custom, and the original plastic steering wheel is cracked in numerous places. I am about to take it through our local DMV to get a Roadworthy Certificate, if I don't replace the steering wheel it will never pass.
Just wondering what other Mopar OEM plastic steering wheels are compatible (year range)? I would like to put a Tuff Wheel or a two spoke Steering wheel (like on E-Bodys etc) on it, but I think I need a Boss Kit?
Due to our Road Rules if I don't have an OEM Steering Wheel it won't pass (can't have after market Steering Wheels).
Any help much appreciated.
Re: 1972 Dodge D100 Steering Wheel compatibility? [Re: Adam_Downunder] #1643907
07/08/14 03:42 AM
07/08/14 03:42 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
I think most wheels will work, I know I have used a Omni/Horizon wheel on my '88, most recently, and tried it on my '85and it fit.
The differences are more, tilt or non tilt column, the tilt columns were built I believe by Saginaw (GM) and use a different spline, same I think as most GM.
So, a wheel from a non tilt column should work. When you get up into the later, fat column years, not so sure.
I sort of use the size of the column as my guide.
Sometimes I use the listings for after market wheel adapters as a guide.
Clear as mud now, right?
It takes gasoline to interest me.
Re: 1972 Dodge D100 Steering Wheel compatibility? [Re: VL21] #1643908
07/08/14 06:25 AM
07/08/14 06:25 AM
Australia
Australia
Cheers thanks for the head's up.
Now it's just a matter of finding a crack free one on eBay..
Re: 1972 Dodge D100 Steering Wheel compatibility? [Re: Adam_Downunder] #1643909
07/08/14 12:01 PM
07/08/14 12:01 PM
Alberta
rustbuckett68 Offline
Alberta
You could take the wheel off, and repair and repaint. A little epoxy and time should get you there. Lots of videos on the old interweb.
Re: 1972 Dodge D100 Steering Wheel compatibility? [Re: rustbuckett68] #1643910
07/09/14 12:37 AM
07/09/14 12:37 AM
Australia
Australia
Cheers! Thanks for the good advice, I think I am going to do as you suggested, I watched some Youtube vids and it doesn't look too difficult. I think it may be simpler for the time being
Eventually I will change the Steering Wheel, but after I fix it I won't be in such a rush..
Re: 1972 Dodge D100 Steering Wheel compatibility? [Re: Adam_Downunder] #1643911
07/10/14 01:55 AM
07/10/14 01:55 AM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
You could buy a "tuff wheel" and can and be good to go.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: 1972 Dodge D100 Steering Wheel compatibility? [Re: dynotune440] #1643912
07/11/14 04:51 AM
07/11/14 04:51 AM
Australia
Australia
Thanks - I just checked them out online. Because the below comes with the adapter, it should bolt on?
I think I would much prefer a Tuff Wheel over a plastic one..
http://www.ebay.com/itm/CHALLENGER-CHARG...403&vxp=mtr
Re: 1972 Dodge D100 Steering Wheel compatibility? [Re: Adam_Downunder] #1643913
07/17/14 02:31 PM
07/17/14 02:31 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I think people have already given you the skinny on this. I'm shocked to see they would fail a vehicle for this. Broken metal spine I could understand. There's probably tens of millions of cars in the US with cracked steering wheels.
I want my fair share
