Okay, I figured it out.
The bearing housing (holds the turn signal switch) has two square headed bolts running up from the bottom. The heads ride in channels cast into the housing.
The nuts on these bolts must be just barely threaded onto the bolts to give you as much play as possible.
I borrowed this photo from an old thread so ignore the arrows. The square bolt heads are visible:
When sliding the bearing housing over the shaft and into place the square heads of the bolts side over the main column tube into the square slots on each side.
Another borrowed photo, ignore the arrow, slots are at top and bottom in this pic. The bolt heads most go outside this tube and slip into slots:
You tighten them alternating from side to side and it holds the housing firm to the main column.
Hope this helps someone else.
