Re: Dipstick tube broken,any Ideas?
[Re: ademon]
#1643735
07/07/14 11:48 PM
07/07/14 11:48 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It's a light press fit, if you can lightly thread a tap into it and pull on the tap with vice grips. Use grease in the flutes of the tap so as to not put metal shavings in the oil.
[Re: CraigS]
#1643737
07/08/14 12:15 AM
07/08/14 12:15 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I will try those ideas guys. Pulling the motor is such a chore for a dipstick tube!!!
No need to go that route if the above don't work,just remove the oil pan.
[Re: Cab_Burge]
#1643741
07/08/14 05:00 PM
07/08/14 05:00 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If it's a driver and the labour involving dropping the pan is outweighed by risk.
If pulling offending tube is unsuccessful. Consider knocking the offending tube into the oil pan with a drift.
The chance of the offending tube causing any problems is pretty thin. You may even try using a boroscope and magnet to fish it out.
[Re: Magnum]
#1643742
07/08/14 07:39 PM
07/08/14 07:39 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
You'll never get it back out the dipstick hole on the block if you push it into the pan !!
[Re: CraigS]
#1643746
07/09/14 06:33 AM
07/09/14 06:33 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
guys I did get it out(see above post).Acually ,the timing cover is off so getting the stub out would be fairly easy out the front of the block.But now ,I cant find my original tube ,it was here last night.....what did I do with it????
look over by the drill press,leaning up against the stand.
