Page 2 of 3 1 2 3
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: BulletBob] #1643592
07/13/14 02:11 AM
07/13/14 02:11 AM
Jerseyville Il.
syco Offline
syco  Offline
Jerseyville Il.
I recently drug home a (11/77) 78 crew long bed dually. Has an in cab tank and regular one. All looks factory. I haven't looked that hard at it but was told it was a factory big block truck.
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: BulletBob] #1643593
07/13/14 11:52 AM
07/13/14 11:52 AM
Canada
demon Offline
demon  Offline
Canada
Slightly off topic, but over the years I have owned and driven many of these trucks.
I had a 73 D100 with dual tanks. One in cab and one under, but only one gas cap. The filler neck had a Y in it and one branch went straight into the cab tank, and one branch went down, through the floor and into the frame tank. You simply stuck the nozzle in horizontal to fill the cab tank, or stuck it in pointing down to fill the frame tank.
On my current 75 W100 440 shortbox, it only has the in cab tank but has two gas caps. The one on the box is a painted dummy cap which is screwed in place. I had another like that too.
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: demon] #1643594
07/13/14 07:07 PM
07/13/14 07:07 PM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
I have a 73 D200 ClubCab w/400 with the dual tanks / one filler also.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: shinnery] #1643595
07/13/14 11:09 PM
07/13/14 11:09 PM
It's beer:30 somewhere
adventurer Online content
adventurer  Online Content
Been out to Carlisle and just got back, while there I picked up a book that I had never seen before for 77 Dodge trucks. It is the 1977 Dodge Truck Sales Manual. In it it breaks down standard equipment, available packages, whats new for 1977 and additional factory installed options. It covers all trucks, Ramchargers, Sportsman wagons, Tradesman Vans, d500,600 & 700 trucks, Motorhome chassis pretty well all aspects of the truck line for that year. There were some options that I had no idea were available and were a first for that year, but my point to this is in the additional factory installed options for d100,d200,d300,w100,w200,w300 and w400 it lists and I quote "HL4 In-cab 24 gal. cap. mtd. behind seat on conv. or crew-cab sweptline pick-up models N.A. w/hinge-back bench seat" so it was available but the seat would have not folded forward, as in the bucket seat "buddy seat" package like in my truck or a fixed bench seat that did not fold forward. So I think there is the answer as far as 77 is concerned.
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: adventurer] #1643596
07/14/14 11:49 AM
07/14/14 11:49 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
My '76 Adventurer sport (short bed) came with an in cab, and in frame tank. I took the in cab tank out. For what I use it for, it doesn't need it. I also got tired of the sloshing sounds all the time. The in frame tank gives me plenty of fuel.
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: bigblock340power] #1643597
07/14/14 12:41 PM
07/14/14 12:41 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
My eyes are not that great but this one seems to have 2 tanks. https://denver.craigslist.org/cto/4567715143.html
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: Geezer] #1643598
07/14/14 01:40 PM
07/14/14 01:40 PM
Geezer thanks for posting that link. If you look at the original schedule notice it does say code HL4 Fuel tank 24 gal in cab w/??? I can't read the last three letters looks like it might say lid but I'm not sure.
14 Ram R/T
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: adventurer] #1643599
07/15/14 12:37 AM
07/15/14 12:37 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
This is the correct wording for the HL4 option.
HL4 24 gals.---In Cab behind seat---For use with 131" wb. Conv and 165 wb. Crew Cab Sweptline pickups only. Not available with Hinged-Back Bench Seat.
The standard tank was frame mounted in front of the rear axle. The HL4 in cab was in addition to the factory frame mounted tank.
I ordered my 77 reg cab short box 4x4 new and I could not get an auxiliary tank. I added the new tank before I drove it. The bench seat with the fold down back would work but the release levers had to be bent on a 45 degree so they would not rub through the tank. 30 seconds with a 12 inch crescent wrench fixed that.
Again if someone can prove they had a factory short bed regular cab put up the documentation. Just because it has one now does not mean it rolled out of the factory with one 36 years ago.
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: BulletBob] #1643600
07/16/14 02:43 AM
07/16/14 02:43 AM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
After mid 75 model year there were no more in cab tanks in the factory service manuals or parts catalogs
Really, my factory parts manual shows them through 78...and seen 79 utilines with them, and had an 80 govt blm crew cab with one.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: NITROUSN] #1643601
07/16/14 02:58 AM
07/16/14 02:58 AM
dynotune440 Offline
dynotune440  Offline
They are out there. Biggest way to tell if factory or not is the nice Metal decal next to the switcher valve switch in the dash below the ac controls... if it is there and says "STD in AUX out", then it is factory. There was no replacement part for that decal... if its got that decal, and no in bed spare tire mount, then its factory.
But what do I know...I'm friggin stupid when it comes to these trucks....
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: dynotune440] #1643602
07/16/14 09:28 AM
07/16/14 09:28 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I don't know about D100 but my 78 D300 had both the saddle and in - cab tanks from the factory.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: dynotune440] #1643603
07/17/14 12:35 AM
07/17/14 12:35 AM
Back home in PA
BulletBob Offline OP
Back home in PA
My parts manual is a little worn That's why I was surprised to see it in the 78-84 manual I have
It may be missing some pages but I have a brand new NOS one I can break out when I get home
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: dynotune440] #1643604
07/17/14 04:08 AM
07/17/14 04:08 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
...the nice Metal decal next to the switcher valve switch in the dash below the ac controls... if it is there and says "STD in AUX out", then it is factory.
OIF V and OEF X veteran and proud of it!
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: 69HemiGTX] #1643605
07/17/14 03:26 PM
07/17/14 03:26 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
About 8 people in the entire world care if a 70s Dodge truck gas tank came factory or not. All 8 found this thread.
I love Moparts
I want my fair share
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: SomeCarGuy] #1643606
07/17/14 03:28 PM
07/17/14 03:28 PM
dynotune440 Offline
dynotune440  Offline
Yes, yes in deed.....
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: SomeCarGuy] #1643607
07/18/14 10:07 AM
07/18/14 10:07 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
I love Moparts
But twice as many people replied to this thread.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: Soopernaut] #1643608
07/18/14 12:04 PM
07/18/14 12:04 PM
I love Moparts
14 Ram R/T
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: adventurer] #1643609
07/18/14 01:03 PM
07/18/14 01:03 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Some posted what they had seen or had, some posted other questions or comments, not that many were passionate as the rest
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: SomeCarGuy] #1643610
07/18/14 06:29 PM
07/18/14 06:29 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
I saw 77 and 440 so I had to come in. I often wonder how many Macho PW's came in 77 with long bed and 440? Oh and no it does not have a cab tank.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: BulletBob] #1643611
07/18/14 07:38 PM
07/18/14 07:38 PM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
I've run into a guy who claims his truck is one of less than 100 77 D150 Custom with a 440
Since there is no possible way to prove this, he could say whatever.
I have one 2wd shortbed, two 2wd Longbeds and 5 clubcabs in registry.
4wd's? Have 15 shortbeds.
Please register your Dodge truck here 1972-1980 Dodge truck registry
Page 2 of 3 1 2 3
