Re: How many 77 1/2 ton 440 Trucks with in cab tank?
[Re: MachoMan]
#1643612
07/19/14 01:21 PM
07/19/14 01:21 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
He won't reply to my messages or emails I may have asked him so many questions & such that he didn't want to lie so much & get caught The letter code in the VIN question ended our conversation as it seems That or the request for the codes from the data plate that he said was present
[Re: MachoMan]
#1643613
07/20/14 01:06 PM
07/20/14 01:06 PM
Posts: 5,302 CA, Proprietor; The "PALOMINO"...
dynotune440
I've run into a guy who claims his truck is one of less than 100 77 D150 Custom with a 440
Since there is no possible way to prove this, he could say whatever.
I have one 2wd shortbed, two 2wd Longbeds and 5 clubcabs in registry. 4wd's? Have 15 shortbeds.
No way to assess that, no numbers for 77, but the car guru says 121 for 76 model, and 74 units for 78... soon who knows...sure there is something somewhere...but it has not surfaced yet.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
[Re: dynotune440]
#1643616
07/21/14 02:25 PM
07/21/14 02:25 PM
BulletBob
Back home in PA
Fleet orders for sure...
No doubt there But none listed for SWB trucks no matter what seat it came with
[Re: BulletBob]
#1643617
07/22/14 12:46 AM
07/22/14 12:46 AM
dynotune440
Bob... I still have to differ there, seen plenty of ssb 77 and a few 78 trucks with an in cab tank that was auxiliary. Just to blow your mind a little, and I will have to look up the code, but there is a code that is for a special tank configuration in cab only, not in frame, and was on 76 and 77 d100 trucks.. have a 76 like this in my yard...
[Re: dynotune440]
#1643619
07/22/14 01:24 AM
07/22/14 01:24 AM
BulletBob
Back home in PA
Special tank code HL4...
Reads as such from Chrysler for 1977
HL4 24 gals-in cab behind seat-for use with 131" WB Conv and 165"WB CrewCab Sweptline pickups only.Not available with hinged back bench seat
Shortbeds are 131" WB?
[Re: BulletBob]
#1643620
07/22/14 12:39 PM
07/22/14 12:39 PM
Posts: 983 The Sierras
LAST440
The Sierras
78 small block PW. There wasn't a switch or a decal on the dash for one obvious reason.
Truckin' Thru Life
