Page 3 of 3 1 2 3
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: MachoMan] #1643612
07/19/14 01:21 PM
07/19/14 01:21 PM
Back home in PA
BulletBob Offline OP
Back home in PA
He won't reply to my messages or emails
I may have asked him so many questions & such that he didn't want to lie so much & get caught
The letter code in the VIN question ended our conversation as it seems That or the request for the codes from the data plate that he said was present
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: MachoMan] #1643613
07/20/14 01:06 PM
07/20/14 01:06 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
I've run into a guy who claims his truck is one of less than 100 77 D150 Custom with a 440
Since there is no possible way to prove this, he could say whatever.
I have one 2wd shortbed, two 2wd Longbeds and 5 clubcabs in registry.
4wd's? Have 15 shortbeds.
No way to assess that, no numbers for 77, but the car guru says 121 for 76 model, and 74 units for 78... soon who knows...sure there is something somewhere...but it has not surfaced yet.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: dynotune440] #1643614
07/20/14 03:10 PM
07/20/14 03:10 PM
Back home in PA
Back home in PA
Sam I would have to agree with you
I figured the car guru didn't put forth much effort in the truck department & let the numbers slide in the dumpster
I find it funny when these guys claim these numbers & actually no one knows
The guy I'd been talking with displayed every view & what I did see was the wrong angle & length on a in cab filler neck
131" wb Conv cab = Reg Cab with 8' bed
165" wb Crew cab = the farmers son I know is probably right
I know I've seen a bunch of tow,tug,dump,roll,sweeper & host of other commercial style trucks with an in cab & that is a given by it being available in the parts books up into the 80's
Dealer installed only or truck body vendor it seems possibly factory through the dealer commercial Truck department
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: BulletBob] #1643615
07/21/14 02:17 AM
07/21/14 02:17 AM
dynotune440 Offline
dynotune440  Offline
Fleet orders for sure...
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: dynotune440] #1643616
07/21/14 02:25 PM
07/21/14 02:25 PM
Back home in PA
Back home in PA
No doubt there But none listed for SWB trucks no matter what seat it came with
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: BulletBob] #1643617
07/22/14 12:46 AM
07/22/14 12:46 AM
dynotune440 Offline
dynotune440  Offline
Bob...
I still have to differ there, seen plenty of ssb 77 and a few 78 trucks with an in cab tank that was auxiliary.
Just to blow your mind a little, and I will have to look up the code, but there is a code that is for a special tank configuration in cab only, not in frame, and was on 76 and 77 d100 trucks.. have a 76 like this in my yard...
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: dynotune440] #1643618
07/22/14 12:52 AM
07/22/14 12:52 AM
dynotune440 Offline
dynotune440  Offline
Special tank code HU9...
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: dynotune440] #1643619
07/22/14 01:24 AM
07/22/14 01:24 AM
Back home in PA
Back home in PA
Special tank code HL4...
Reads as such from Chrysler for 1977
HL4 24 gals-in cab behind seat-for use with 131" WB Conv and 165"WB CrewCab Sweptline pickups only.Not available with hinged back bench seat
Shortbeds are 131" WB?
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: BulletBob] #1643620
07/22/14 12:39 PM
07/22/14 12:39 PM
The Sierras
LAST440 Offline
LAST440  Offline
The Sierras
78 small block PW. There wasn't a switch or a decal
on the dash for one obvious reason.
Truckin' Thru Life
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: SomeCarGuy] #1643621
07/22/14 12:43 PM
07/22/14 12:43 PM
The Sierras
LAST440 Offline
LAST440  Offline
The Sierras
About 8 people in the entire world care if a 70s Dodge truck gas tank came factory or not. All 8 found this thread.
I love Moparts
9 people
Truckin' Thru Life
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: BulletBob] #1643622
07/22/14 04:11 PM
07/22/14 04:11 PM
dynotune440 Offline
dynotune440  Offline
Nope, 119" wb.
Chrysler print was subject to change....
Now if I can find a build sheet for one...lol
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: dynotune440] #1643623
07/22/14 04:55 PM
07/22/14 04:55 PM
Back home in PA
Back home in PA
That's what the link Barry posted displayed from Chrysler word for word
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: BulletBob] #1643624
07/29/14 01:19 AM
07/29/14 01:19 AM
South Coast of Oregon
dweller Offline
dweller  Offline
I've got a '77 W200 Crew. It has the in-cab tank and NO external tank. It came this way from the factory. Frame tank required different cross-members, so if the truck came with one, I would see signs of the original cross-members being removed, frame re-riveted, etc. Bottom line, this truck left the factory with an in-cab tank and no other tanks...
Re: How many 77 1/2 ton 440 Trucks with in cab tank? [Re: dynotune440] #1643625
07/29/14 02:40 PM
07/29/14 02:40 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Nope, 119" wb.
A regular cab , short bed 72-93 truck had a 115" wheelbase.
1970 Dodge d100/eventually going on a 77 D100 frame
Page 3 of 3 1 2 3
