heating a paint booth. propane heater? anyone use one?
#164341
12/08/08 04:45 PM
12/08/08 04:45 PM
Posts: 1,349 warfordsburg, PA
dirt
warfordsburg, PA
Re: heating a paint booth. propane heater? anyone use one?
[Re: dirt]
#164342
12/08/08 05:32 PM
12/08/08 05:32 PM
Step away from the open flame. You're looking at disaster.
Sheldon
[Re: dirt]
#164343
12/08/08 05:38 PM
12/08/08 05:38 PM
Posts: 942 Virginia, US
RTDaddy
super street
super street
Virginia, US
If the booth is in a building, try to set-up so the booth draws from the building, and heat the building. If you're looking at an open flame heat source directly into the booth, , we may have a candidate for the first booth in low earth orbit. "IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
#164344
12/08/08 05:43 PM
12/08/08 05:43 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Sheldon
people can die this way.
your paint will be giving off flamable fumes during the curing process.
[Re: fox]
#164349
12/08/08 09:02 PM
12/08/08 09:02 PM
Posts: 1,378 Back In Iowa
belv2vert66
Back In Iowa
This is very interesting to me, Back in the day, I worked in very large cabinet manufacturing plants. We sprayed plenty of solvent based products including lacquers. Anyway we had huge conveyor systems that after the spray booth and flash off areas, there were huge ovens. I am talking like 40 x 100 feet. In these ovens there was a HUGE gas fired burner with like a 2 foot flame flying out of it. The burner would cycle on and off depending on the temp the thermostat was set at. There were/are several fans also in there circulating air and also exhausting fumes. Let me tell you, you could not go in this oven without being overcome with the fumes, to me it had to be flammable. I have never asked anyone, but I am assuming they were using the gas fired burner to produce positive pressure in the oven, so as long as the fumes never got to the flame, it would not blow up. I have always thought, If a guy used lets say a house furnace, and could make the fan run continuously and then introduce the flame, it would be the same principle. Obviously you would have to have filters to the outside and somewhere for the air/fumes to go out, like a traditional positive pressure booth, or the fumes would eventually back up to the flame. Obviously, the air the furnace used to burn, could not be exposed to the fumes. If the cold air came from the outside, it would only raise that air a certain temp. Could be trouble in sub zero type weather Someone smarter than me has to have an opinion on this but there has to be literally hundreds of these ovens in the US curing flammable coatings. LOL. I think this principle could work, just don't want to experiment with it.......
[Re: dirt]
#164351
12/08/08 09:46 PM
12/08/08 09:46 PM
Challenger 1
Cincinnati, Ohio
I have painted many a truck in a 30x40 area with a good exhaust fan in the wall. We have a 65K LP infra red heater hanging from the ceiling and use it all the time to dry paint after the fumes have cleared. Been doing it since 1984. Also have a smaller one mounted on a 100# tank on a 2 wheel dolly, use it for spot heating and paint drying. Some spray booths use gas infer red heat to cure the clear after the fumes are cleared out.
So to answer your question, no it won't hurt the paint. But you got to be careful in smaller inclosed areas with portable gas heat.I don't think I'd try any kind of heater with a blower around paint. Keep any open flame well up off the floor in any garage.
[Re: belv2vert66]
#164355
12/09/08 11:55 AM
12/09/08 11:55 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
OK, You are right; a real paint booth setup uses a direct fired make-up air unit (usually natural gas)in conjunction with a dedicated and interlocked exhaust fan. As you've hypothesized, these units use 100% outdoor air. We've installed around a hundred of them over the years. There isn't an explosion hazard if the ventilation rate is sufficient; i.e. the flamable vapours are exhausted and the positive airflow is in the opposite direction. Contaminated air cannot get to the burners.
In this particular circumstance, I wouldn't recommend a direct fired heater.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#164357
12/09/08 09:07 PM
12/09/08 09:07 PM
belv2vert66
Back In Iowa
So in theory, I could use a high efficiency gas fired furnace to build positive pressure in the room or booth. As long as the inlet air was clean. The key would be to make sure the contaminated air had an big enough outlet so that the fumes didn't back up. Again, I am pretty sure this would work, it's that proving part that is making me nervous.
[Re: dirt]
#164359
12/09/08 10:43 PM
12/09/08 10:43 PM
Challenger 1
Cincinnati, Ohio
just finished my paint job. 3 coats paint, 2 coats clear with flake, 3 coats clear. top and bottom of car and i didnt blow up. also painted tail stripe.
so everyone can calm down now.
Good job on not blowing up.
How'd the paint job come out?
