1970 cuda console base difference #1643272
07/07/14 01:30 PM
07/07/14 01:30 PM
long island n.y.
E
ek2aar Offline OP
ek2aar  Offline OP
E
long island n.y.
Is there a difference between a 70 and 71 console base, I know the tops are different, with the ash tray/ seat belt holder, and the difference between an auto and 4 speed, but not between the bases, is there a different part #? If so, what is the correct# for a 70? Thanks
Re: 1970 cuda console base difference [Re: ek2aar] #1643273
07/07/14 01:34 PM
07/07/14 01:34 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The base has the alignment fins for the seatbelts, so yes, the '70 pieces are different.
Re: 1970 cuda console base difference [Re: 6bblgt] #1643274
07/07/14 01:47 PM
07/07/14 01:47 PM
long island n.y.
E
ek2aar Offline OP
ek2aar  Offline OP
E
long island n.y.
So the 71 and up have no fins? Or different fins?
Re: 1970 cuda console base difference [Re: ek2aar] #1643275
07/07/14 02:06 PM
07/07/14 02:06 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
70 only base on top.
71 and up on bottom.
Note height of mounting tabs on each.
You cant mount a 71-up top to a 70 bottom or vise-versa.
Re: 1970 cuda console base difference [Re: mccannix] #1643276
07/07/14 02:11 PM
07/07/14 02:11 PM
Ontario, Canada
Ontario, Canada
Note different ribbing and extra mounting boss on 70-only end, pictured on top.
Only one mounting boss and different ribbing on the 71-up end below.
Re: 1970 cuda console base difference [Re: mccannix] #1643277
07/07/14 02:37 PM
07/07/14 02:37 PM
long island n.y.
E
ek2aar Offline OP
ek2aar  Offline OP
E
long island n.y.
Perfect, thanks guys
Re: 1970 cuda console base difference [Re: ek2aar] #1643278
07/07/14 11:11 PM
07/07/14 11:11 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
If you want to connect the dots....
The console door hinge: Try to keep/obtain a 1970 hinge. The later versions don't fit correctly when used with the 1970 console.
