Flare On My Shift #1642781
07/06/14 11:14 AM
07/06/14 11:14 AM
MR_P_BODY Offline OP
On my Rampage with a 518 trans it has a flare when
shifting from 2nd to 3rd... what is the normal cause
for a flare on the 2-3 shift... I'm gonna be pulling
the pan in a day or so, so I'll check the bands and
I want to check the valve body for any sticky valves
thanks
Re: Flare On My Shift [Re: MR_P_BODY] #1642782
07/06/14 11:40 AM
07/06/14 11:40 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
not familiar with the 518 but if they are like a 727/904 then the intermediate band is out of adjustment,(the one on the outside of the case) I run mine in with my fingers as tight as I can and back out 1.5 turns, that is with a 4.2 ratio arm,,if it pulls the motor down at shift then it is too tight and I usually back the adjuster 1/4 turn at a time untill it go's away. this is with my 904
Re: Flare On My Shift [Re: dartman366] #1642783
07/06/14 11:49 AM
07/06/14 11:49 AM
Thanks Bill... thats pretty much what I figured...
this one has the stock arm which I believe is 3.9
but that ends up being the pressure it applies and
is a little bit of a time issue when it applies
EDIT
A 518 is a 727 with a OD... also the 518 has some
bigger clutches and a couple other parts that are
a bit better than a 727
Re: Flare On My Shift [Re: MR_P_BODY] #1642784
07/06/14 02:51 PM
07/06/14 02:51 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yup you're on the right track Mike. Basically the 2nd gear turns off faster then the 3rd gear drum can apply.
The only other thing it could be is if the high gear clutch is taking a Sh!t, but you'll see a lot of clutch material in the pan.
I can't remember, what clutches did we put in that thing? Alto's or Raybesto's tans?
Re: Flare On My Shift [Re: dizuster] #1642785
07/06/14 03:57 PM
07/06/14 03:57 PM
I dont recall either but I think they were Raybestos..
I'm gonna pull the pan to put a drain and temp boss
on it so I'll see what kind of trash is in the pan
Re: Flare On My Shift [Re: MR_P_BODY] #1642786
07/06/14 07:09 PM
07/06/14 07:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
did it happen all at once or was it progressive?
Re: Flare On My Shift [Re: dartman366] #1642787
07/06/14 07:12 PM
07/06/14 07:12 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Let me know what you find. If it looks like there is a bunch of junk in it, we can go through the trans.
I have another one to do this week anyway, so just bring it over and I'll take care of ya...
Re: Flare On My Shift [Re: dartman366] #1642788
07/06/14 07:13 PM
07/06/14 07:13 PM
Cant really say Bill... I dont get on it a lot on
the street and when I just putt.. it isnt real noticeable
(it just doesnt jump out at me but I'm sure its been
doing it a while but getting worse)
Re: Flare On My Shift [Re: dizuster] #1642789
07/06/14 07:20 PM
07/06/14 07:20 PM
Thanks Scott.. I have to look at the down shift..
this thing doesnt like to unless I pull it down or
if I give the throttle a few blips while sitting still..
I'll see whats in the pan first
Re: Flare On My Shift [Re: MR_P_BODY] #1642790
07/08/14 12:58 PM
07/08/14 12:58 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Raff , how many springs did you put in the front (direct) Drum , I don't think adjusting the band is going to fix it.
Re: Flare On My Shift [Re: JohnRR] #1642791
07/08/14 01:23 PM
07/08/14 01:23 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
When I went from the 340 to the 416 I had the same thing happen to my 904 on the first pass. I thought I missed the shift! It was a pretty low end setup that I had bought with the low end fish. Adding fluid helped some making it mostly go away. Taking the tranny to PTC hopefully has it fully fixed.
Re: Flare On My Shift [Re: Airwoofer] #1642792
07/08/14 02:17 PM
07/08/14 02:17 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
This sounds like you found the limit of that particular build of the trans.
Raff's flare is more than likely the front band releasing faster than the front clutch is applying. A number of things could be causing it, fluid path leak , too many springs in the front clutch and/or too many springs in the front servo.
Re: Flare On My Shift [Re: JohnRR] #1642793
07/08/14 08:13 PM
07/08/14 08:13 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have also seen cases with a restrictor in the high drum feed used in some shift kits that can cause this problem depending on what has been done to the unit now.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Flare On My Shift [Re: dusturbd340W5] #1642794
07/08/14 09:50 PM
07/08/14 09:50 PM
When Scott and I went through this it was basically
a stock rebuild with a Trans-go shift improver kit
so I think it has the stock number of springs but
I also went with the 727 input shaft and pump so I
could run one of my high stall conv in it
Re: Flare On My Shift [Re: MR_P_BODY] #1642795
07/08/14 11:47 PM
07/08/14 11:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mike, I have always run 15 springs in my 727's w/o flare. Personally unless there is something in the valve body giving an issue I don't believe you can have to many.
Doug
Re: Flare On My Shift [Re: dvw] #1642796
07/09/14 12:00 AM
07/09/14 12:00 AM
Doug
Well being this was a junkyard trans that Scott and I
went through I think it has a valve body issue and/or
a governor issue.. being it doesnt like to down shift
so in a day or so when I get the wife home from the
hospital I'm gonna drop the pan and the valve body..
I want to see if the valves are hanging up or are free
Re: Flare On My Shift [Re: MR_P_BODY] #1642797
07/09/14 09:55 AM
07/09/14 09:55 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I trust your wife's surgery went off without a hitch?
Kevin
Re: Flare On My Shift [Re: Twostick] #1642798
07/09/14 10:00 AM
07/09/14 10:00 AM
Kevin
Yes it did, thanks.... I just got done talking to her
and she said its hurting now but they have some good
drugs for her... she will be coming home tomorrow
EDIT
they replaced her shoulder so it was a bit more work
than just repairing
Re: Flare On My Shift [Re: dvw] #1642799
07/09/14 10:46 AM
07/09/14 10:46 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Doug
Last one I built had 12 or 15 with about .080 clearance , a billet front servo from Randy J with both springs and I can't remember if it was a 3.8 or 4.2 lever set at 2.5 turns out and a Cope full auto valve body. It flared on the 2-3, removed one of the springs in the servo and dropped down to 9 springs , flare up gone , but with both done at the same time I not sure which one was the fix... it was fixed by someone else because of schedule conflicts and that is what the guy did that fixed it.
Re: Flare On My Shift [Re: JohnRR] #1642800
07/09/14 10:54 AM
07/09/14 10:54 AM
Doug
I have the stock 3.8 arm in it now.. I'll drop the
pan first and check out the VB and readjust the bands
then go from there... IF need be I'll pull the trans
