Flare On My Shift
#1642781
07/06/14 11:14 AM
07/06/14 11:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
On my Rampage with a 518 trans it has a flare when shifting from 2nd to 3rd... what is the normal cause for a flare on the 2-3 shift... I'm gonna be pulling the pan in a day or so, so I'll check the bands and I want to check the valve body for any sticky valves thanks
Re: Flare On My Shift
[Re: MR_P_BODY]
#1642782
07/06/14 11:40 AM
07/06/14 11:40 AM
dartman366
Mt. Vernon, Ohio
not familiar with the 518 but if they are like a 727/904 then the intermediate band is out of adjustment,(the one on the outside of the case) I run mine in with my fingers as tight as I can and back out 1.5 turns, that is with a 4.2 ratio arm,,if it pulls the motor down at shift then it is too tight and I usually back the adjuster 1/4 turn at a time untill it go's away. this is with my 904
[Re: dizuster]
#1642785
07/06/14 03:57 PM
07/06/14 03:57 PM
MR_P_BODY
Yup you're on the right track Mike. Basically the 2nd gear turns off faster then the 3rd gear drum can apply.
The only other thing it could be is if the high gear clutch is taking a Sh!t, but you'll see a lot of clutch material in the pan.
I can't remember, what clutches did we put in that thing? Alto's or Raybesto's tans?
I dont recall either but I think they were Raybestos.. I'm gonna pull the pan to put a drain and temp boss on it so I'll see what kind of trash is in the pan
[Re: dartman366]
#1642788
07/06/14 07:13 PM
07/06/14 07:13 PM
MR_P_BODY
did it happen all at once or was it progressive?
Cant really say Bill... I dont get on it a lot on the street and when I just putt.. it isnt real noticeable (it just doesnt jump out at me but I'm sure its been doing it a while but getting worse)
[Re: dizuster]
#1642789
07/06/14 07:20 PM
07/06/14 07:20 PM
MR_P_BODY
Let me know what you find. If it looks like there is a bunch of junk in it, we can go through the trans.
I have another one to do this week anyway, so just bring it over and I'll take care of ya...
Thanks Scott.. I have to look at the down shift.. this thing doesnt like to unless I pull it down or if I give the throttle a few blips while sitting still.. I'll see whats in the pan first
[Re: Airwoofer]
#1642792
07/08/14 02:17 PM
07/08/14 02:17 PM
Posts: 75,326 A gulag near you.
JohnRR
A gulag near you.
When I went from the 340 to the 416 I had the same thing happen to my 904 on the first pass. I thought I missed the shift! It was a pretty low end setup that I had bought with the low end fish. Adding fluid helped some making it mostly go away. Taking the tranny to PTC hopefully has it fully fixed.
This sounds like you found the limit of that particular build of the trans.
Raff's flare is more than likely the front band releasing faster than the front clutch is applying. A number of things could be causing it, fluid path leak , too many springs in the front clutch and/or too many springs in the front servo.
[Re: dusturbd340W5]
#1642794
07/08/14 09:50 PM
07/08/14 09:50 PM
MR_P_BODY
I have also seen cases with a restrictor in the high drum feed used in some shift kits that can cause this problem depending on what has been done to the unit now.
When Scott and I went through this it was basically a stock rebuild with a Trans-go shift improver kit so I think it has the stock number of springs but I also went with the 727 input shaft and pump so I could run one of my high stall conv in it
[Re: dvw]
#1642796
07/09/14 12:00 AM
07/09/14 12:00 AM
MR_P_BODY
Mike, I have always run 15 springs in my 727's w/o flare. Personally unless there is something in the valve body giving an issue I don't believe you can have to many. Doug
Well being this was a junkyard trans that Scott and I went through I think it has a valve body issue and/or a governor issue.. being it doesnt like to down shift so in a day or so when I get the wife home from the hospital I'm gonna drop the pan and the valve body.. I want to see if the valves are hanging up or are free
[Re: dvw]
#1642799
07/09/14 10:46 AM
07/09/14 10:46 AM
JohnRR
A gulag near you.
Last one I built had 12 or 15 with about .080 clearance , a billet front servo from Randy J with both springs and I can't remember if it was a 3.8 or 4.2 lever set at 2.5 turns out and a Cope full auto valve body. It flared on the 2-3, removed one of the springs in the servo and dropped down to 9 springs , flare up gone , but with both done at the same time I not sure which one was the fix... it was fixed by someone else because of schedule conflicts and that is what the guy did that fixed it.
[Re: JohnRR]
#1642800
07/09/14 10:54 AM
07/09/14 10:54 AM
MR_P_BODY
I have the stock 3.8 arm in it now.. I'll drop the pan first and check out the VB and readjust the bands then go from there... IF need be I'll pull the trans
[Re: MR_P_BODY]
#1642801
07/09/14 01:03 PM
07/09/14 01:03 PM
JohnRR
A gulag near you.
Pull the front servo also and look at the springs/ how many and the type of servo and what was done , cushion type that is blocked solid ? ... unless the band is real loose (is the 1-2 delayed ?) I having a hard time seeing it being the fix but here's a little
[Re: John_Kunkel]
#1642803
07/09/14 02:05 PM
07/09/14 02:05 PM
MR_P_BODY
What kit exactly? If it's the TF series the orifice restrictor in the case might be the problem...it can be removed to speed up the front clutch apply.
I dont have any idea of the restrictor or where its located... maybe Scott will remember and I dont recall the kit number but Scott should know that because its what he normally uses on this type of trans.... I bought a trans book that covers the 500,518 and the 618 so I'll see if I can find that restrictor in the VB
[Re: John_Kunkel]
#1642806
07/09/14 05:07 PM
07/09/14 05:07 PM
MR_P_BODY
Here's a pic of the Transgo restrictor orifice installed in the case. Remove the VB, thread a sheet metal screw into it and pull it out with a clawed pry bar or claw hammer.
[Re: MR_P_BODY]
#1642807
07/09/14 08:28 PM
07/09/14 08:28 PM
Posts: 3,640 Oakland, MI
dizuster
Oakland, MI
I am almost positive that we DID put the orifice restriction in it, but I've done a couple of these in the past, so I can't remember for sure.
The Transgo kit gives full manual control, but will also "shift" in drive. The kit was the TFOD-HD2.
It's been so long, I can't remember how many springs we put in the direct drum, but I'm fairly certain it was 12 if I remember right. I don't remember going out of our way to add any extra's, unless they were supplied with the kid (which I don't think they are).
Loose band will cause it to "flare", but will also show signs of a soft 1/2 shift (as JohnRR mentioned). Could have ripped the high gear drum seal for some reason too? How about the throttle pressure? maybe it's not seeing full kickdown pressure, and the low apply pressure is acting like a "flair"?
[Re: dizuster]
#1642808
07/09/14 08:45 PM
07/09/14 08:45 PM
MR_P_BODY
I know I have the throttle pressure down some so it will shift early.. I'll look at that and the band when I get the chance... thanks guys
