polishing grill shell & side trim on my 84 D150 #1642273
07/05/14 05:12 PM
07/05/14 05:12 PM
Crockett ,TX
9
98RAM1500 Offline OP
Crockett ,TX
does anyone know a good way to polish the grill shell and the wheel lip trim on my 84 D150? what products & methods did you use?
thanks
Re: polishing grill shell & side trim on my 84 D150 [Re: 98RAM1500] #1642274
07/05/14 08:49 PM
07/05/14 08:49 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
For any type of aluminum trim you need to remove the "bright dip annodizing" first. Sanding is one way, but difficult. The fastest/easiest is a chemical strip. Once stripped you can repair or polish the piece but it will no longer have any protection and will eventually oxidize.
Forget oven cleaners - too weak. Sodium Hydroxide (found in Drano Kitchen Crystals) will do it. I've done it very successfully in a container large enough to submerse the piece. Hot water, dump a bunch of crystals in till dissolved. (Safety disclaimer: Wear goggles, gloves, adequate ventilation as some hydrogen gas will be produced. Proceed at your own risk!!!!! No lectures, please).
Place the piece in the dip. Some small bubbles will form (and a tiny amount of gas). Keep an eye on it. In 20 minutes or less all of the bright dip coating will be gone. Rinse the piece under cold water. You may have to rub off some gray colored "smut" or residue on the surface - it will come off easily. You'll be left with a clean aluminum part ready for polishing.
With all that said, this DIY process is probably not practical on a grille shell. Headlight bezels, straight trim, yes. I made a dip tank for long straight pieces out of vinyl rain gutter with end caps. No matter how you do it, it's a lot of work. Consider sending it out to someone who specializes in this sort of restoration.
Re: polishing grill shell & side trim on my 84 D150 [Re: 70Duster440] #1642275
07/05/14 09:19 PM
07/05/14 09:19 PM
Truckville, the capital of NY
85_Ram_4speed Offline
The only oven cleaner I ever found to work was Easy Off in the Yellow can. I think it's the original version. If you use that and a 3M grey scotch brite pad after it sits for a bit, it should all come off.
Then it is just basic metal polishing. I use a buffing wheel on a bench grnder with various compounds. You can hand polish, but it takes ALOT of time.
Outcast Dodge guy.
Re: polishing grill shell & side trim on my 84 D150 [Re: 85_Ram_4speed] #1642276
07/06/14 01:11 AM
07/06/14 01:11 AM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
Me too. Some lite sanding with increasingly finer grits up to 1000 before polishing makes a nice job. (assuming all imperfections have been tapped out)
