valve spring question #1642088
07/04/14 11:25 PM
07/04/14 11:25 PM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
hey guy's, i need to put my head's back together but i got a small problem, as i was pulling the spring's off the head 1 retainer poped off an well it's gone now lol, i am asking what kit would work with my stock 318 valve's in my 714 head's?? i am also running the comp 901 spring's as well... just need some help so i can get the girl back on the road thanks for any info guys
drive fast, drive hard, DRIVE MOPAR
Re: valve spring question [Re: lifted85] #1642089
07/05/14 12:21 AM
07/05/14 12:21 AM
Are you needing just (1) keeper? how many grooves?
Re: valve spring question [Re: RapidRobert] #1642090
07/05/14 02:38 AM
07/05/14 02:38 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
I'm missing 1 intake an 1 exhaust retainer... i got a set of 74 heads i could pop 1 off but all the retainers are flat not pushed down i would say lol. was also told the deg could be different... if i could find a kit i would be set... iirx they are 2 grooves
Re: valve spring question [Re: lifted85] #1642091
07/05/14 03:50 AM
07/05/14 03:50 AM
SE PA
Yellow Fever Offline
SE PA
So you need the retainer and not the keepers? The keepers are available on Rockauto but the retainers????? They have to be somewhere, I would look for the old ones, they don't just evaporate.
318cid V8 : Engine : Valve Spring Retainer Keeper
SEALED POWER Part # VK66 {#VK66R}
2 groove; Hardened
SEALED POWER Part # VK138 {#VK138A, VK138R}
w/.371" stem dia.; 1 groove; Square cut key groove; Hardened
w/.371" stem dia.; 1 groove; Square cut key groove0
SEALED POWER Part # VK174 {#VK174R}
4 groove; Hardened
http://www.ebay.com/itm/Edelbrock-9720-Valve-Spring-Retainers-/200721388954?_trksid=p2054897.l4275
Re: valve spring question [Re: Yellow Fever] #1642092
07/05/14 01:21 PM
07/05/14 01:21 PM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
Ita gone lol, ita not like i was in a shop it went flying out side some where an i looked for 2 days lol. . will them edelbrock retainers work with the stock 7 deg keepers???
