4-speed gurus unite.
#1641890
07/04/14 10:48 AM
07/04/14 10:48 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Car: '69 Super Bee. Trans:rebuilt 833. History: shifts fine, needs a little shifter and clutch adjustment. Cause(?): u-joint failure, driveshaft vibrating enough to hit the floor pan. New symptom:Under deceleration, pops out of high gear. Not violently. Just let off the gas and it shifts itself out of gear. It doesn't fight going back in, just pops our every time. Question: Adjustment problem? Could the vibration (severe)have knocked somethinf loose or broken something inside? I'm also getting a vibration in the clutch pedal. I didn't notice it before, but it may have been there?? I just need to know if I'm going to need to pull the transmiasion out again, or maybe just adjust it.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: 4-speed gurus unite.
[Re: OhioMopar]
#1641891
07/04/14 01:11 PM
07/04/14 01:11 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have seen these U-joint failures shake so violently the advance plate shook loose inside the distributor. The same car cracked the bellhousing and extension housing too. If all your adjusments are fine I wouldn't be surprised to find some internal damage. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1641892
07/04/14 02:05 PM
07/04/14 02:05 PM
OhioMopar
Mt.Gilead, Ohio
Drat. I guess I'll pull it and open it up. It shook enough the console and glove box door popped open.
[Re: fourgearsavoy]
#1641902
07/05/14 03:10 PM
07/05/14 03:10 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
You left out the skirt, heels, and purse in that picture of the girl's muscle car transmission. Real muscle cars have three pedals. Slushboxes are for women Gus
Yeah, sure they are...
Why don't you tell everybody how many times you've been waxed by a 'slushbox'???
Autos have been pounding Ronnie wanna-be's in these parts for many years...
[Re: BDW]
#1641904
07/05/14 03:40 PM
07/05/14 03:40 PM
Posts: 5,268 NY
70440+6bbl
NY
I've always wondered why 4spd cars sell for more than autos. The auto was an expensive option, so there were less made?
In reality almost no 1 can "out shift" and auto?
It is just the nostalgia factor?
Untrue, in most every case, the automatics outsold the manual trans.
Given the choice, I would never buy an automatic muscle car (have owned over 100 in nearly 27 years, 99% of them were factory 4-gear cars)... Nor would most enthusiasts that I know. We all know that autos have the potential to be more consistent, but that's irrelevent to me, as I'm not out racing every Tom, Dick and Harry on the street. Bench seats and pistol grips, that's where it's at!!!
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: 70440+6bbl]
#1641905
07/05/14 05:54 PM
07/05/14 05:54 PM
OhioMopar
Mt.Gilead, Ohio
Anyone got any more ideas on what causes a trans to pop out of 4th. Enjoyable derailment of the thread, but I still have the same issue!
[Re: RSNOMO]
#1641909
07/05/14 09:43 PM
07/05/14 09:43 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
If you didn't have this trouble before the u-joint issue, then I think a look inside that trans is in order...
In 50 years of messing with '833s, I've only found two causes for "popping out of gear"...
> Shift linkage maladjusted so the slider isn't 100% engaged
> Worn dog teeth on the speed gear (in your case, the main drive pinion). You have to look carefully, kind of a tapered or diagonal wear pattern.
Hard to imagine, though, how a bad u-joint could cause either of these defects. I'm thinking -- long shot -- bent / twisted mainshaft?
Rick
